johnnyb44 Posted June 13, 2024 Share Posted June 13, 2024 I have reviewed past discussions but was unable to locate the specific process. Multiple negative responses. There are no features such as assisted braking, stability control, and others. need I go directly to the garage, or are there any preliminary tasks I need do first, please? Despairing woman. The 2014 Evoque I believe it is at the highest end of the spectrum. Only 40,000 kilometres. Quote Link to comment Share on other sites More sharing options...
johnnyb44 Posted June 13, 2024 Author Share Posted June 13, 2024 Furthermore, I would want to inquire about the legality of operating the aforementioned vehicle. Quote Link to comment Share on other sites More sharing options...
torque2me Posted June 13, 2024 Share Posted June 13, 2024 I had a similar issue, where the problem was identified as the front nearside wheel sensor. LR support promptly replaced it within an hour. This resolved the issue well. 👍 Quote Link to comment Share on other sites More sharing options...
johnnyb44 Posted June 13, 2024 Author Share Posted June 13, 2024 Appreciation is extended. I lack an extended warranty and reside in a really remote area. Fortunately, the nearby garage will service and pickup it. The noise I heard when reversing up an incline suggests that the issue may be with the rear wheel on the non-driver's side. I am curious to know whether this is an insurance claim or if you are looking for an estimated cost. Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted June 13, 2024 Share Posted June 13, 2024 This year, I purchased a high-quality rear sensor for my 2013 vehicle at a cost of £50. Installation may be completed in less than one hour. Simply instruct the garage to verify the item number, since there are several sensors available depending on the specific model and equipment. This task should be affordable and any skilled mechanic can do it; there is no need for an expert. Quote Link to comment Share on other sites More sharing options...
johnnyb44 Posted June 13, 2024 Author Share Posted June 13, 2024 Thank you; comforting. Upon consulting the Manual, I discovered the significance of the several cautions with the phrase "seek urgent...". This caused me to anticipate the most dire outcome. Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted June 13, 2024 Share Posted June 13, 2024 Additionally, it has the capability to remove the speedometer and power steering. These messages are crucial, yet they can be simply repaired. Quote Link to comment Share on other sites More sharing options...
johnnyb44 Posted June 13, 2024 Author Share Posted June 13, 2024 Indeed, the speedometer was no longer functioning and I also experienced the absence of power steering. It seems that the whole **** lot is affected. Thank you for suggesting that it can be simply resolved. Quote Link to comment Share on other sites More sharing options...
trikey Posted June 13, 2024 Share Posted June 13, 2024 Many systems depend on just one or two sensors, so if one of them fails, all the systems that rely on it will generate alerts, which may be rather alarming. I am aware that when many warning lights illuminate simultaneously, it is quite unlikely that all of those components have malfunctioned simultaneously. Therefore, I would speculate that the issue is with the rear driver's side wheel speed/ABS sensor. Quote Link to comment Share on other sites More sharing options...
johnnyb44 Posted June 13, 2024 Author Share Posted June 13, 2024 Thank you; maybe it was a mere coincidence, but I saw a disturbance in the back non-steering wheel at the same instant it occurred, like a little shock. Quote Link to comment Share on other sites More sharing options...
Black_raven Posted June 13, 2024 Share Posted June 13, 2024 🤞🤞 Quote Link to comment Share on other sites More sharing options...
