paulh2602601 Posted August 27, 2024 Share Posted August 27, 2024 Is there someone available to assist me? The alarm on my 2021 Evoque was activated, causing the vehicle to become entirely immobilised. I am unable to both open and shut it. Despite using the manual key to enter, the automobile remains completely unresponsive. The symptom is identical to that of a battery being deactivated. It is non-functional. The Incontrol app indicates that the alarm has been triggered and is now obstructed. The travel help department lacks the knowledge and ability to fix the issue. Is there anybody who has a resolution? Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted August 27, 2024 Share Posted August 27, 2024 If you are able to reach the battery, attempt to unplug it for a little period of time and thereafter reattach it. Occasionally, this action may restore the vehicle's systems to their original state. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 Completed. No alterations.... Everything remains unchanged. Totally lifeless! Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 Ah! The battery is overheating. I subjected myself to the act of burning in order to loosen the negative terminal. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 The automobile completed its charging process 30 minutes ago. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 Ha! The battery is overheating. I subjected myself to the act of burning in order to loosen the negative terminal. Quote Link to comment Share on other sites More sharing options...
xsports Posted August 27, 2024 Share Posted August 27, 2024 I am certain that the 12-volt battery should not reach a temperature high enough to cause burns, even immediately after completing the charging process. There is another occurrence taking place. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 Indeed, you are correct. The 12-volt battery was depleted. This morning, my buddy and I used a booster to start the vehicle, and it started without any issues while the booster was connected. I purchased a new battery. Extracting the battery proved to be a complex procedure; nonetheless, it was successfully removed from the vehicle after a duration of one hour. After installing the new battery, I followed the reverse procedure of reassembling all the components, and the vehicle is now functioning flawlessly. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 The issue with the temporary unavailability of the electric vehicle (EV) seems to have been resolved. For the time being. Let's observe in the next days. Quote Link to comment Share on other sites More sharing options...
Rudy7831 Posted August 27, 2024 Share Posted August 27, 2024 Are the terminals thoroughly sanitised and free from any signs of corrosion? Consider thoroughly cleaning and lubricating all components. Then attempt a thorough recharge. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 The 12-volt battery was completely discharged. Both terminals are free of dirt or debris, but, the previous battery did not receive or take in any electrical charge. A fresh battery has been connected, resulting in the restoration of full functionality. Thank you. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 The only issue I am now facing is the blockage of the Remote App. The automobile has been reported as stolen, and I am unable to take any action about it. According to Land Rover's customer service, I must visit a dealership in order to resolve this problem. Does anybody have knowledge of a method to reset the Incontrol App? Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted August 27, 2024 Author Share Posted August 27, 2024 The Incontrol App unexpectedly reset itself 30 minutes ago, while the cause is unknown to me. Thank you nonetheless. Quote Link to comment Share on other sites More sharing options...
