Reinstallation of E90 battery
MDMH757
I removed the battery a few weeks ago to recharge it. Reinstalled with the apparatus positioned on top. Devoid of electrical power. No apparent authority to any entity. I wondered if I'd damaged the 'contraption' so re-checked today. In my particular vehicle, the piece seems to serve no use. I questioned if I had blown a main fuse; however, it seems that all fuses are located below the glovebox, and I am uncertain whether a 'main fuse' exists.
The battery is functioning well. Do you have any recommendations?
Typically exceeds that amount.
Inspect the distribution point for corrosion and measure the voltage at the junction of the large red cable and the negative terminal of the battery. Subsequently, repeat the measurement using the other lead cable connected to the chassis, ensuring that the voltage remains consistent.
Typically, there are more wires than those seen above. In your first image at the top, does there seem to be a red cable? To what is it connected? I anticipated it would also be linked to the battery, since I believe it would provide power to your fuse board.
Additionally, my vehicle has a slender cable that emerges next to the linked connection, which may sever if corrosion occurs due to moisture in the battery compartment. I am not asserting that your automobile has the cable, but you would have seen it when removing the battery.
