xDrive Acceleration Delay.
allmightyASTON
Good morning, everyone.
My N47 F31 has begun to exhibit significant hesitation during acceleration, resulting in a prolonged sense of sluggishness. Once at optimal velocity, it operates steadily and smoothly, devoid of any unpleasant sounds or other indications of malfunction.
During my recent trip, I observed that there is no hesitation during acceleration in 1st and 2nd gears, whereas the issue seems to begin from 3rd gear forward.
Initially, I suspected a Transfer Case malfunction; but, when recognizing that the problem mostly manifests from 3rd gear forward, I am now contemplating a gearbox issue.
I used ISTA+, which did not provide any fault codes for any component. However, when I scanned with Bimmerlink this morning, it documented the following codes:
Five faults in the central gateway module
101008: Non-resolvable ambiguous routing - SG absent from the SVT target table
101010: SIF error 100104: Hardware fault reason ZGW
100001: VcmResultSvtCheck - identification verification: Discrepancies between the actual SVT and the target SVT have been identified.
100204: Message monitoring: absence of system context signal 12
Two faults in motor electronics
27AC00: Internal DDE control unit (cyclical authentication): Program status verification failed
27AB00: Internal DDE control unit (cyclical authentication): data record verification failed 1C
Two faults in integrated chassis management
48276E: Autosar - StandardCore - Non-Volatile Memory - Integrity compromised 482656: Slip angle estimate - internal deterioration attributed to SBS
Does anybody possess insights or experiences about similar hesitation concerns, and if so, how were they resolved?
I own the ZF repair kit for the transmission and the appropriate fluid for the transfer case, which should address the issue; nevertheless, I anticipate that this may be too optimistic.
I appreciate your time in advance for reading this.
All tires are uniform and brand new. I have consistently changed them in sets of four, since I am aware that xDrive may be somewhat particular.
The issue has arisen unexpectedly, since everything was functioning well just a few days before. The engine operates smoothly in Neutral and functions optimally overall, mostly due to your work on the chains; thus, I suspect an issue with the gearbox or torque converter. It is disappointing because it does not generate a diagnostic code.
Update - I removed the TC fuse, and the vehicle operated flawlessly, confirming it was really a TC problem.
I replaced the fluid (about 450ml) and executed the calibration using ISTA+, resulting in the vehicle returning to a near-normal state.
I shall do another fluid change in about one week, since the fluid that was expelled was very dark and likely original from the manufacturer.
It is perplexing that they no longer provide a drain cap, since it complicates the process of extracting the oil.
It is prudent to repeat the process in about one week if the condition was so severe.
I hope that resolves the issue completely.
I apologize for not seeing your previous post on the 21st.
