Tyre repair kits for do-it-yourself (DIY) use.
VVC-Geeza
What was the level of complexity? I am inquiring since I will soon be transitioning from runflat tyres to regular tyres. Due to the lack of room in the BMW, the proposed solution is to carry a compressor and a repair kit that uses a string-based method to cure punctures. This choice is made since there is a lack of trust in the effectiveness of a can of sealant to repair a puncture.
I have equipped all of our vehicles and my bike with screws and a screwdriver as a contingency measure. I already had the strings, but I have never used either of them.
There are several YouTube videos demonstrating the simplicity of using the screws, which influenced my decision.
There was a screw lodged in the tyre. Extracting the screw was a simple task. Enlarging the hole with a reamer was also straightforward. Threading the string through the hole was not difficult. However, inserting the string into the hole was somewhat challenging. The insertion tool became bent in the process, but ultimately, the string was successfully inserted.
Convenient timing, since a buddy encountered a pothole earlier and I was uncertain whether to fix the damage myself or seek assistance from the AA.
This prompts the inquiry: what are the advantages and disadvantages of doing a do-it-yourself repair on a tyre that supports one corner of a 1.5 kg automobile, covering a distance of 8,000 miles, while driving at speeds up to the maximum legal limit?
An acquaintance of ours was travelling on the autoroute to come and see us. Perforation. Tyre damaged. Neither any quantity of adhesive substance nor any temporary repair on the side of the road could rectify the issue. I recommended that he get an additional one, even if it is simply a slim one.
That's the action we took with our Yaris, and it proved beneficial when the tyre encountered a forceful curb. Wear the slim-fitting clothing.
Subsequently, we discovered a precise match for the alloy wheel priced at £120, resulting in the acquisition of a total of 5 alloy wheels, mirroring the number of wheels on my 300CE.
Self-assurance.
Indeed? Do automobile manufacturers produce vehicles that lack space for a spare tyre? I was unaware of it.
I utilise the string variety, specifically purchasing those that are marketed as a permanent fix rather than a temporary one. I am uncertain whether there is really any difference, but it provides me with a sense of comfort! Ever since I found out about string repair kits, I have not had to use a spare tyre. I have consistently carried a compact 12-volt compressor to expedite the process of repairing and inflating the tyre, which is more time-efficient than replacing the wheel. Clearly, they are ineffective for repairing sidewalls. The insert tool shown by is not the tool I use. My kits include a screw-like file that can be used to expand a hole to a size that allows the string to pass through. There is also a more pointed tool that is used to feed the string into the hole, and once inserted, the string remains in the hole after a sharp and quick pull. The thickness of Toeknees' body hindered the ease of pushing through, which likely explains why his considerable power was able to bend it.
I used the reaming tool as instructed to expand the hole, but, I had difficulty in inserting the strip. I revisited the task and used the reamer once again. I believe the kit I used was of low quality, and the strips were too thick. This experience has prompted me to purchase a more robust version of the insertion tool.
