Starcar2022 Posted September 27, 2023 Share Posted September 27, 2023 Greetings, I would want to inquire if a deployed driver-side airbag can be repaired or whether it necessitates the purchase of a replacement unit. It has been observed that in the event that a new airbag is deemed necessary, the whole seat will undergo replacement, a process that is known to provide challenges in terms of accessibility and availability. I kindly want guidance and advice, please. I am in possession of a 2017 Mazda 3 automobile.I express my gratitude for your assistance. Quote Link to comment Share on other sites More sharing options...
honeycut_mazda5 Posted September 27, 2023 Share Posted September 27, 2023 When seeking assistance, it is beneficial to include the specific year and model of your Mazda vehicle. In some instances, individuals using different devices may have difficulties in promptly locating the position of a thread. In this particular scenario, the trim level may be a determining factor. Quote Link to comment Share on other sites More sharing options...
Starcar2022 Posted September 27, 2023 Author Share Posted September 27, 2023 Apologies. I am in possession of a 2017 Mazda 3 vehicle. I am grateful for your assistance and extend my appreciation to you. Quote Link to comment Share on other sites More sharing options...
honeycut_mazda5 Posted September 27, 2023 Share Posted September 27, 2023 Please specify the trim level you are referring to. Could you please specify if the chairs are made of leather or cloth? Quote Link to comment Share on other sites More sharing options...
honeycut_mazda5 Posted September 27, 2023 Share Posted September 27, 2023 It is essential to replace the air bag. In the event that the airbag was deployed in accordance with its intended design, it may be inferred that the break/away thread experienced a fracture, hence facilitating the deployment of the airbag without causing any damage to the seat material. The airbag may be readily changed, and any automotive upholstery establishment has the capability to stitch or sew the panels that encase the airbag using breakaway thread. If the material has been torn, it is expected that the upholstery business would possess the capability to substitute the affected panel. The process of replacing the air bag and repairing the seat is rather straightforward, provided that there is no sun fading or extreme wear. It is advisable to see an Auto upholstery shop in order to get comprehensive repair services for the air bag and seat panel. We delegate the task of repairing the air bag, even though we possess the capability to do the replacement ourselves, mostly due to the preference of the upholstery business we engage with to undertake the whole process. Typically, based on many factors, it is customary to remove the customer's seat and transport it to the upholstery business. Once the upholstery work is completed, the seat is reinstalled and the Supplemental Restraint System (SRS) is thoroughly inspected. Quote Link to comment Share on other sites More sharing options...
Starcar2022 Posted September 27, 2023 Author Share Posted September 27, 2023 Thank you for your prompt reply. It is advantageous to possess knowledge of this information, since I was previously unaware of the appropriate course of action. The chair in my possession is upholstered with leather material. I am required to locate an upholstery establishment in Toronto that has the capability to do this task. Quote Link to comment Share on other sites More sharing options...
honeycut_mazda5 Posted September 27, 2023 Share Posted September 27, 2023 If the information provided indicates that it is a specialized thread, it may be concluded that this is not the case. The user's text is an expression of amusement. From a technical standpoint, if one were to adhere strictly to the guidelines set by vehicle manufacturers at their respective dealerships, it is specified that the threading mechanism is designed to be loosened under a certain level of external force. In order to address this issue, it is recommended that individuals use a thread with a reduced weight. However, it is advisable to refrain from making any assumptions about the pricing or availability of a particular thread unless the supplier explicitly communicates this information or indicates that it is only available for purchase in bulk quantities. Furthermore, this statement is not accurate. Quote Link to comment Share on other sites More sharing options...
