Engine RPM fluctuations
stevenkeyte
I own a 2008 BMW 520d N47, to my knowledge.
Recently, I have spent in excess of £4,500 on a range of repairs, including:
    Substituting gaskets
    Replacing the gearbox fluid
    Modifying ECU modules
    Substituting the timing chain
    Draining the DPF (I have been advised that it was remapped and the DPF was removed, resulting in blockage, therefore necessitating the draining)
The vehicle exhibits an issue between 1500 and 2000 RPM, characterised by fluctuating revolutions and hesitation during acceleration.
I have conducted mechanical testing on all components, including:
    Turbocharger Turbo actuator Exhaust Gas Recirculation (EGR)
    Throttle body and all vacuum lines, which underwent smoke testing.
    Intercooler
Notwithstanding all these examinations, the problem endures and stays unaddressed.
The garage has now indicated that it must be an electrical problem.
Any recommendations, please?
An somebody with more expertise in mapping and software may provide insight, but I believe that assertion is inaccurate; a software update restores oecus to their factory defaults.
A map may not resolve the issue, but it seems peculiar; therefore, it requires thorough verification. If the mapping was conducted with the DPF disabled, the absence of the DPF will impact boost levels. Conversely, if it has reverted to factory specifications without a DPF, this will also have repercussions.
