modules impacted by temperature
Are there any known modules on the E64 630i that may be impacted by low temperatures? My vehicle has a delay in activation upon unlocking, characterised by a central electronics failure. Initially, the windows are inoperative, and the engine fails to crank. After about two minutes, it eventually cranks and starts. Any assistance would be appreciated.
The automobile starts without issue after around 2-3 minutes. I just purchased a Bluetooth battery monitor; however, as previously said, I conducted diagnostics using Bimmerlink and an Autel IM508 Pro. All errors, save for the fuel pressure sensor, have cleared.
I measured the battery voltage before to beginning, which was 12 volts. After starting, it charged at 14.8 volts. Upon switching off, the voltage decreased to 12.4 volts. I have recently connected a Bluetooth battery monitor, which indicates a battery percentage of 54%, whereas BimmerLink displays 77%.
