DenishP4 Posted July 22 Share Posted July 22 Greetings, everyone. How are you? May I inquire, please? E 220 W211. Anterior brake caliper. I am seeking the carrier. However, I am unable to locate any information on this component or its part number. The caliper is functioning well. New pins have been installed. There seems to be some residual movement. Please include any component number, if available. Thank you, everyone. Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted July 22 Author Share Posted July 22 I entered my chassis on the Partsouq website. I examine my brake diagram and get a component number. Section 75 on the diagram. Brake anchor. A 000 420 61 15 The graphic indicates it is for the front brake, although a Google search identifies it as the rear brake. It does not state "back," but "rear" refers to the back. The front and back are indeed distinct. My vehicle is equipped with a single piston caliper, however the 300 D has a two piston caliper. Despite my attempts to purchase a caliper, it does not display the carrier or mount bracket. I must be able to get my share. Recently, I removed it and neglected to search for the component number.Alas! Thank you, everyone. Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted July 22 Author Share Posted July 22 Greetings. Neglected to include the diagram link. Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted July 22 Author Share Posted July 22 https://partsouq.com/en/catalog/genuine/unit?c=MB201810&ssd=%24*KwHC9uePu5zOz7O8sp7dzJqOrqm3xsnExdf4y4OFtqG1ub-35eLytLS4o6OlpL3n4MWvgYWBsKaytpuWisDBzsWywcTAkZKCjpK2jNKF1M6L4fzS3dSa0suYgcXLl9KW1M3Cx8DNkNrFhbGN1YTTzNbr6pnc05_VysLHzZmSl9KW1M3Bws7BnZbGjoeTn7CK1IKLnZmntbTFwcDGxJGV-cDDws_FyNTYi8rY0svUxcHAxsSRhZfSgpXVytPU2IvK0NLL1MbS3dSXx4WB0sfCotLd1ILKhYHSwNSKAAAAAFdsL0o%3D%24&vid=0&cid=26699&uid=31905&q=WDB2110082B024859 Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted July 22 Share Posted July 22 Contact the parts department of your local Mercedes-Benz dealer using the Vehicle Identification Number (VIN). At the very least, you can be certain that they will provide the appropriate component. 👍 Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted July 22 Author Share Posted July 22 Indeed, it seems to be all I am capable of doing. I verified the rear schematic for the identical component, and the numbers match; both indicate 'rear' when I search on Google for purchase. I will either examine my own vehicle to see whether I can access the necessary area or contact them; nevertheless, I feel somewhat compelled to make a purchase when I do so. Merely my eccentric sentiment..lol. Remain calm, everyone. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted July 22 Share Posted July 22 Purchasing from Mercedes poses no difficulties. Components are often extremely cheap, and one cannot ascertain this unless an inquiry is made. 👍 Quote Link to comment Share on other sites More sharing options...
EnchantedScribe Posted July 22 Share Posted July 22 It is amusing how often individuals here assert that; hence, it may have validity in certain cases. Alternatively, I may just have had misfortune, since every component I have inquired about at my local Marshalls has been available at far lower prices elsewhere, often identical to the original part. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted July 22 Share Posted July 22 Components of the pattern will, naturally, be less expensive. Occasionally, it is advisable to incur additional costs when the component number is uncertain. I have used MB Newcastle and Edinburgh DIY components and have found them to be quite competitive. Quote Link to comment Share on other sites More sharing options...
