MDMH757 Posted October 24 Share Posted October 24 My car has recently encountered a significant problem with excessive fuel use. I previously achieved a minimum of 450 miles on a half tank, but now I am only attaining approximately 300 miles at best, and I am uncertain as to the reason. The vehicle receives a full tank and undertakes a 300-mile motorway excursion weekly. I regularly undertake extended motorway drives at 70 mph for over three hours, so I doubt it could be the DPF, although I am not totally certain. I previously had an exhaust back pressure sensor problem that resulted in a powertrain fault on iDrive; however, after replacing the sensor, the vehicle no longer displays that fault. I have poured DPF cleaner to a full tank and executed another thorough drive on the freeway, but to no avail. I have recently undergone a significant service that has yielded no results. I consulted BimmerUtility, which indicates my soot levels are at 45.99g. I have observed this value decrease to 8g, but it occasionally spikes to the high teens or abruptly returns to approximately 45.99g. I previously had a 24C800 error, which was resolved by replacing the sensor. However, I am now facing a 25C800 error. Does this indicate that the DPF need replacement and is it the source of the problem? Quote Link to comment Share on other sites More sharing options...
HOV Posted October 24 Share Posted October 24 Verify if the pre-turbine pressure sensor pipe is unobstructed; if it is clear, replace the sensor and reset the settings. It is also advisable to inspect the brakes to ensure none are binding, as this significantly impacts fuel economy. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted October 24 Author Share Posted October 24 Is the pre-turbine sensor pipe the conduit that links to the exhaust back pressure sensor? Upon inspection, it appears to be clear. I also inspected the brakes, and they are in satisfactory condition. Quote Link to comment Share on other sites More sharing options...
HOV Posted October 24 Share Posted October 24 The steel pipe originates from the banjo bolt on the manifold, with the sensor inserted into a little rubber part at the end. Quote Link to comment Share on other sites More sharing options...
