diablos_carcv5 Posted 19 hours ago Share Posted 19 hours ago My aim is to decarbonise the cylinder head, replace the malfunctioning swirl motor, substitute the oil cooler seals (despite the presence of purple seals, it is prudent to address them), replace the leaking AC condenser and clean the DPF. I am not providing a comprehensive photographic tutorial; if you lack the requisite skills, consider hiring a professional. However, if you wish to do it and possess the necessary competence, numerous resources are available on this forum and YouTube. I am undertaking this to identify any potential difficulties and address any enquiries that may arise, if possible....and might pose some enquiries of my own. This was intended to commence in the new year; but, the weather has been excessively chilly, prompting me to begin today. The forecast predicted dry conditions; it was inaccurate!Despite having the entire day, I only accomplished approximately four hours of work amidst the intermittent showers. I spent half an hour attempting to remove the DPF, which I have yet to accomplish. I will initiate a separate topic with this issue. This occurred around 9 o'clock this morning.Only the cover has been removed. Quote Link to comment Share on other sites More sharing options...
diablos_carcv5 Posted 19 hours ago Author Share Posted 19 hours ago Quote Link to comment Share on other sites More sharing options...
diablos_carcv5 Posted 19 hours ago Author Share Posted 19 hours ago This occurred approximately three and a half hours later...gulp! Quote Link to comment Share on other sites More sharing options...
diablos_carcv5 Posted 19 hours ago Author Share Posted 19 hours ago I intended to convey that the purple seals had a sealant applied. To my knowledge, none is required. Am I mistaken, or was the previous owner only exercising excessive caution? Quote Link to comment Share on other sites More sharing options...
motorman3 Posted 19 hours ago Share Posted 19 hours ago No sealant on the purple seals, my friend. Should the glow plugs be replaced when everything is disassembled? Well done! Quote Link to comment Share on other sites More sharing options...
diablos_carcv5 Posted 19 hours ago Author Share Posted 19 hours ago The glow plugs are functioning adequately and are easily accessible in the event of failure; therefore, I will defer any action regarding them for the time being. 👍 Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted 19 hours ago Share Posted 19 hours ago Valiant individual! I will remain in the kitchen - suitability varies by context! Quote Link to comment Share on other sites More sharing options...
vitessear3 Posted 19 hours ago Share Posted 19 hours ago Excellent effort, best of luck; undoubtedly more courageous than I. Quote Link to comment Share on other sites More sharing options...
diablos_carcv5 Posted 19 hours ago Author Share Posted 19 hours ago Understood. I have a brief inquiry. Last night, I was compiling all the torque specifications for reassembly (any comprehensive list would be greatly appreciated). It indicates that the oil cooler screws should be set to 12 Nm, which seems appropriate; however, some sources state that they are stretch bolts and must be replaced, while others do not mention this requirement. Is anyone aware? I will likely replace them nonetheless; but, they do not appear to be TTY (stretch) bolts. Salutations. Quote Link to comment Share on other sites More sharing options...
diablos_carcv5 Posted 19 hours ago Author Share Posted 19 hours ago https://www.ebay.co.uk/sch/i.html?_nkw=oil cooler&campid=5338181132&customid=2518X1570512X5cf8b9064c18ddce5b4565b854902679&mkcid=1&mkrid=710-53481-19255-0&subId2=15&toolid=10001 Quote Link to comment Share on other sites More sharing options...
Psychil Posted 19 hours ago Share Posted 19 hours ago Do you possess access to WIS? Quote Link to comment Share on other sites More sharing options...
HOV Posted 18 hours ago Share Posted 18 hours ago I did not use stretch bolts on the W211; I reused the existing ones. Apologies, I cannot recall the torque as it is not included in the extensive thread I created. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted 18 hours ago Share Posted 18 hours ago Continue producing those gastronomic creations. 👍 Quote Link to comment Share on other sites More sharing options...
