The 20th audio with UCI
I recently acquired a 2010 A207 (technically an E class convertible, but it's actually a C class...) equipped with an Audio 20 that has an integrated CD changer. Additionally, it has the Universal Communications Interface (Option 518), as stated on the LastVin datacard. Does it only work with Bluetooth, or can I also use it to play music from an SD card or USB stick? If the latter, where can I find the appropriate connector? It's not here; I've searched everywhere.
Wow, the blue one from Pompey was really good!
Can you think of a USB port on the armrest that might work?
My best guess is that you've already searched the most obvious spot—the glove box.
With the 'Media Interface' on my 2012 E350, I could play music from my iPod classic via Comand.
You may find it in my E400 as well.
You and I have the identical automobile audio system. The vehicle does not have any kind of USB port. When I'm on the road, I plug my phone into the Aux port located in the glovebox. Just this past weekend, I placed an order for a jack-to-USB adapter, which came with a USB stick that I could pair with my phone using Bluetooth. Turned to the cable after failing to use it. I listen to music on my iPhone while driving, but the car's features don't support carplay.
It's the most inconvenient part of the vehicle, but it's necessary for the technology that we use nowadays.
While the car's Bluetooth works well with phones, the prior owner used a device that plugs into the car's 12V socket to create an FM signal for the radio to stream music. Not a very refined answer, but it gets the job done.
On the other hand...
After stepping outside into the light, I can make out what appears to be a media interface connection in the glove compartment. It's tucked away in the dark, towards the back of the vehicle, towards the center, and pointing downwards, so I can't see the contacts inside. However, I am at a loss as to what else it may be. If that's the case, then I can connect my USB stick and the correct cord to the head unit and play my music (he said with a glimmer of optimism).
