Psychil Posted May 9, 2024 Share Posted May 9, 2024 Greetings! The CX-60 is equipped with a Bose system that has around 12 speakers. I am unable to locate one in close proximity to the driver's legs. Is there a possibility that someone has a photograph? One intriguing aspect is the placement of the woofer near the front passenger's legs. It is concealed by a completely enclosed plastic covering. Perhaps due to the presence of a woofer speaker. Quote Link to comment Share on other sites More sharing options...
bl52krz Posted May 9, 2024 Share Posted May 9, 2024 Indeed, they are woofers. The Bose system consists of a total of three woofers, as opposed to the normal arrangement which only has two. Regrettably, they also cause the floor to vibrate. Quote Link to comment Share on other sites More sharing options...
Psychil Posted May 9, 2024 Author Share Posted May 9, 2024 One is located in the trunk, another is positioned on the left side of the passenger's knees, and the last one is located where? Quote Link to comment Share on other sites More sharing options...
bl52krz Posted May 9, 2024 Share Posted May 9, 2024 BOSE premium sound system The Mazda CX-60 has a distinctive 12-speaker Bose sound system that stands out for its exceptional appearance and outstanding performance. The Bose BassMatch engineering approach is taken to a higher level, delivering a robust listening experience with profound, low-frequency impact for everyone present. The central component of the system is a Bose digital amplifier with nine channels of customised equalisation and digital signal processing. It is situated beneath the front seat on the right-hand side. The amplifier incorporates advanced technologies such as Bose Centerpoint 2 surround sound, Bose SurroundStage processing, and Bose AudioPilot 2 noise-compensation. The 12 speakers are designed for great performance. The instrument panel is equipped with a single 80 mm Twiddler. Each door mirror patch has a 25 mm neodymium tweeter. The body frame incorporates two 115 mm high-excursion neodymium woofers, each housed in a purpose constructed cowl-side bass enclosure with a volume of four litres. The audio system consists of four 80 mm neodymium mid/high range speakers, with one speaker installed in each door. Additionally, there are two rear 65 mm surround speakers, with one speaker put in each C pillar. The system also includes a 130 mm neodymium woofer, housed in a custom-engineered bass enclosure with a volume of 10 litres, located in the spare wheel housing. Quote Link to comment Share on other sites More sharing options...
bl52krz Posted May 9, 2024 Share Posted May 9, 2024 Directly from Bose. And outside of their native habitat: Quote Link to comment Share on other sites More sharing options...
bl52krz Posted May 9, 2024 Share Posted May 9, 2024 Environment: Quote Link to comment Share on other sites More sharing options...
Psychil Posted May 9, 2024 Author Share Posted May 9, 2024 Expressing gratitude! My CX-60 Diesel Takumi with Bose (2023) does not have a driver woofer. How is it feasible? There is insufficient room available for it. Perhaps someone have an authentic photograph? Quote Link to comment Share on other sites More sharing options...
honeycut_mazda5 Posted May 9, 2024 Share Posted May 9, 2024 The 12 speakers are designed for optimal performance. The instrument panel has a single 80 mm Twiddler speaker positioned at its centre. Each door mirror patch is equipped with a 25 mm neodymium tweeter. Additionally, there are two 115 mm high-excursion neodymium woofers, each housed in a custom-engineered cowl-side bass enclosure with a volume of four litres. These enclosures are integrated into the body frame. The car is equipped with four 80 mm neodymium mid/high range speakers, with one speaker installed in each door. Additionally, there are two rear 65 mm surround speakers, with one speaker positioned in each C pillar. Furthermore, there is a single 130 mm neodymium woofer housed in a custom-engineered bass enclosure with a volume of 10 litres, located in the spare wheel housing. Which one do you personally feel a sense of longing for? Quote Link to comment Share on other sites More sharing options...
