HOV Posted July 6, 2024 Share Posted July 6, 2024 I have had my E90 320d for a considerable period of time, and it has consistently experienced an oil leakage issue. Primarily, the intake manifold is located below the coolant flange and above the starting motor. There is a small reservoir located at the top of the engine near the CCV. If a boost hose is not securely fastened, it will leak from that location and also from the EGR delete if it is not correctly installed. A mechanic acquaintance of mine assured me not to be concerned, as this behaviour is common among vehicles. Therefore, when I do maintenance on it, I typically tidy up the untidiness. Over the years, I have made many replacements of the vortex breather in an attempt to prevent this issue, but it continues to reoccur. I regularly need to replenish the oil, since the oil level drops from the maximum to the minimum mark on the dipstick every 2,000 miles. Is it advisable to revert to the previous toilet paper filter design, despite its negative reputation, which is mostly attributed to inadequate maintenance? If I want to use the toilet roll felt filter, do I just need the filter itself? Will it be compatible with my existing CCV housing? Quote Link to comment Share on other sites More sharing options...
Black_raven Posted July 6, 2024 Share Posted July 6, 2024 I believe the housing exhibited subtle variations, since when transitioning in the other direction, a whole unit was provided for replacement. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 Indeed, I remember that. The first item I read does not mention the need for a new house on the M57. I assume that my M47 is constructed in a similar manner. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 Recently seen a video on YouTube, and it seemed identical to me. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 Â Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 I have placed an order for component number 11127793163, which is the assembly and toilet paper filter. Quote Link to comment Share on other sites More sharing options...
Black_raven Posted July 6, 2024 Share Posted July 6, 2024 The optimal course of action is to ensure that the item in question will indeed be compatible. Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted July 6, 2024 Share Posted July 6, 2024 There are three kinds of casings: loo roll, vortex, and another one whose name I can't recall. Two of them have the same exterior casing, but the third one is bigger. I believe my old e92 335d m57 had the larger redesigned casing, not the vortex or loo roll. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 The transition from using toilet roll in the E39 and E46 to vortex in 2005 in the E90 and E60, and then omitting it entirely in the last technological upgrade of the M57. I think that the N47 and 57 engines are equipped with a double vortex system. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 Have you reverted to using toilet paper for one of your bowel movements? If you did, did you ultimately retain it or revert back to the vortex? Several individuals have reported that reverting to using toilet paper has resulted in a significant increase in central venous pressure. Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted July 6, 2024 Share Posted July 6, 2024 No, I had an MGZTCDTI, which is equipped with the BMW M47 engine.They had toilet paper, and then my E46 330d also had toilet paper. I would remove it and cleanse it using petrol. Additionally, I had a spare new one which I would replace every time I changed the air filter. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 The outcome seems to be unfavourable. I regularly monitored the oil level and found that it had remained unchanged. However, I did not specifically inspect the engine compartment for this purpose. Performed maintenance on the vehicle last Saturday and have since noticed a significant oil leak around the EGR, which is a new issue. The leakage occurred only via the manifold when the vortex breather was installed. The toilet paper filter was rather clean, with little oiliness but without any significant blockage. What is the reason for a leak in the EGR while installing the toilet paper breather? Quote Link to comment Share on other sites More sharing options...
rab60bit88 Posted July 6, 2024 Share Posted July 6, 2024 Oil found underneath the intake manifold and in the starting region is often the result of leaks caused by worn swirl flaps or failing seals on the deletion plugs. However, the source of the oil remains unknown. The condensed crankcase vapour has entered the intake tract via the breather and has been distributed throughout the turbo, intercooler, and manifold. Both kinds of breathers become inefficient when the engine accumulates mileage and blowby occurs, leading to the entry of gases into the crankcase. If I were attempting to address the underlying source of the leak, I would consider installing a catch can. Quote Link to comment Share on other sites More sharing options...
HOV Posted July 6, 2024 Author Share Posted July 6, 2024 Indeed, it seems that the only viable option is to fabricate a catch can, similar to what others have accomplished with the M57 engines. I found it intriguing that oil began to emerge abruptly from the intercooler to EGR connection. Previously, it was only the manifold. Could an accumulation of crank pressure be the cause? Quote Link to comment Share on other sites More sharing options...
rab60bit88 Posted July 6, 2024 Share Posted July 6, 2024 The turbo will create greater pressure than the crankcase, thus it is important to inspect the rubber elbow below for any cracks. In the case of the m57, it is known to break at that location and cause oil to spray over the alternator. Quote Link to comment Share on other sites More sharing options...
