TechnoTrailblazer Posted September 26, 2023 Share Posted September 26, 2023 Our inventory includes a 2014 CX-9 Sport model with a mileage of 124,000. The presence of a distinct odor like burnt oil and the emission of smoke originating from the frontal region of the engine were observed. After careful analysis, it was determined that the issue at hand pertained to the valve cover gaskets. Consequently, the valve cover gaskets were subsequently changed on two separate occasions. Upon seeing the persistent presence of odor and smoke subsequent to the first occurrence, I deduced that an error had been made on my part. There is evidence of oil leakage emanating from the upper section of the exhaust manifold in close proximity to the engine's pulling bracket. Upon doing a thorough cleaning, it has become apparent that there exists oil residue in the vicinity of the exhaust manifold gasket next to the engine pulling bracket. Has anybody else had a similar experience? This is a novel concept to me. There is no presence of coolant in the oil, nor is there any evidence of oil in the coolant. The automobile has not had any instances of overheating. Oil changes are typically recommended to be performed every 5,000 miles. Any assistance would be much appreciated. I express my gratitude in advance. Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted September 26, 2023 Share Posted September 26, 2023 Greetings and welcome to the forum. Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted September 26, 2023 Share Posted September 26, 2023 Let us start by discussing the terminology you have used, namely referring to the engine pulling bracket. In addition, the use of visual aids such as pictures might potentially enhance the understanding and clarity of the subject matter. Quote Link to comment Share on other sites More sharing options...
TechnoTrailblazer Posted September 26, 2023 Author Share Posted September 26, 2023 Located at the forefront of the engine is a conspicuous, massive black bracket with a central aperture. I posit that this is one of two methods used for the extraction of the engine from the automobile. Currently, I am not in close proximity to the vehicle. This is the most optimal picture available on my mobile device. Quote Link to comment Share on other sites More sharing options...
TechnoTrailblazer Posted September 26, 2023 Author Share Posted September 26, 2023 Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted September 26, 2023 Share Posted September 26, 2023 I would want to express my gratitude for the provision of the visual materials. Based on my analysis, it seems to be a valve cover leak. However, the task at hand presents significant challenges due to the engine's suboptimal cleanliness. Quote Link to comment Share on other sites More sharing options...
TechnoTrailblazer Posted September 26, 2023 Author Share Posted September 26, 2023 I would concur with your viewpoint if I had not replaced the gaskets on two separate occasions. Furthermore, while running my fingers down the cover at the seam, I see a complete absence of oil residue. The photographs I have sent were taken prior to doing a thorough cleaning of the objects in order to get a more comprehensive visual examination. Upon doing a thorough inspection of the engine, specifically focusing on the juncture between the exhaust manifold and the engine, I saw the presence of oil seepage in the vicinity of the gasket region while ensuring optimal cleanliness and operating the engine concurrently. Addressing such issue is beyond my capabilities. I will consult a reputable automotive repair facility to investigate the matter. I really appreciate your efforts to provide assistance. Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted September 26, 2023 Share Posted September 26, 2023 Please provide us with information on the findings and outcome. I am intrigued to know if you examined the straightness of the surface area contact after the valve cover was removed. Quote Link to comment Share on other sites More sharing options...
TechnoTrailblazer Posted September 26, 2023 Author Share Posted September 26, 2023 The notion expressed is commendable. Upon my second replacement of the gaskets, I proceeded to meticulously clean the mating surfaces before placing my mechanic's ruler on the cylinder head. Upon observation, the ruler looked to be in a state of alignment and uniformity. Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted September 26, 2023 Share Posted September 26, 2023 Apologies for the confusion. I was referring to the valve cover component specifically. Quote Link to comment Share on other sites More sharing options...
