allmightyASTON Posted September 27, 2023 Share Posted September 27, 2023 I have had recurring issues with electrical malfunctions. The vehicle in question is a Mazda B2200 carbureted model manufactured in 1990. I have encountered a persistent issue over the course of one year, prompting me to do an investigation into the discrepancy between the temperature gauge reading, which indicates a frigid state, and the actual state of the vehicle being completely warmed up. Prior to removing the gauge cluster, I want to gather relevant information about the subject matter. I conducted an examination of the wire that is connected to the temperature sensor. The values exhibited a fluctuation range of 2.98 to 4.05. What is the expected voltage level? The vehicle was in operation throughout that period. According to a source called Street source, it was said that the potential values might be either 2 or 7. I have refrained from inserting a wire into the connector and afterwards establishing a ground connection in order to assess if the gauge exhibits a sudden increase in measurement. When the vehicle's ignition switch is turned to the auxiliary position, all lights on the cluster illuminate. Based on my assessment, it seems that the fuel gauge is functioning with a high degree of precision. The gauge resulted in my vehicle being immobilized on a single occasion. Thank you once again. Quote Link to comment Share on other sites More sharing options...
stevenkeyte Posted September 27, 2023 Share Posted September 27, 2023 Is this the temperature sensor that you conducted the wiring test on? The object is encircled by a blue outline. If the Ignition Switch is in the ON position, grounding the temperature sensor wire to the engine block or a reliable ground should cause the temperature gauge to indicate a high temperature reading. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted September 27, 2023 Author Share Posted September 27, 2023 Yes, that wire is really the correct one. I will attempt to do the suggested action and observe the resulting outcome. Initially, it will be necessary to locate a suitable wire inside the confines of my workshop. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted September 27, 2023 Share Posted September 27, 2023 The temperature gauge regulator is located in close proximity to the thermostat, with a solitary wire extending from it. At a temperature of 176 degrees Fahrenheit (80 degrees Celsius), the electrical resistance between the ground and the terminal should measure around 53 Ohms with a tolerance of plus or minus 4 Ohms. It would be quite advantageous to own an infrared temperature gun in order to measure the temperature subsequent to the engine's operation for a duration of 15 minutes. I am now located in the state of Arizona, where the ambient temperature has not yet surpassed 80 degrees Fahrenheit. Moreover, my personal vehicle's temperature gauge indicates only a marginal increase when engaged in urban driving at present. It is worth noting that my vehicle is equipped with a 195-degree Fahrenheit thermostat, and has a two-row all-aluminum radiator, which may contribute to its cooling efficiency. However, an additional factor contributing to inadequate reading comprehension may be the presence of residual air inside the cooling system. To address this issue, I elevate the front end of the vehicle while ensuring that it is in neutral and the parking brake is engaged. Subsequently, I proceed to operate the engine with the radiator cap off, periodically replenishing the coolant mixture with a 50/50 ratio as necessary. If the radiator is operating at a very low temperature, it is advisable to ensure that the fan clutch is only partly engaged. After a 15-minute drive, assess the tactile characteristics of both heating hoses entering the firewall, and then document your observations. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted September 27, 2023 Author Share Posted September 27, 2023 I own an infrared temperature gun; unfortunately, it is of low quality and does not provide accurate readings. Upon personal experimentation, the obtained results indicated that my body temperature was 8 degrees lower than the expected norm for a human being. Nevertheless, I embarked on a brief 15-minute excursion, during which a portion of the journey may have included operating the vehicle at maximum acceleration. Upon tactile examination, I saw that the upper hose had a pliable texture, allowing for effortless compression to the extent that coolant flow was significantly impeded. It is worth noting, however, that such manipulation would have resulted in potential thermal injury to my hand. The lower hose has a pliable texture and a slightly elevated temperature. In order to ascertain the ohmic value, it is imperative that I locate my voltmeter, which seems to have been misplaced. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted September 27, 2023 Author Share Posted September 27, 2023 I have located my multimeter. Upon conducting an examination of the ohm's, it was seen that the values exhibited variation, with the lowest point recorded at 53 and the maximum point at 137. Revision: I inadvertently made contact with the gauge. Remained immobile. I have reason to believe that the gauge is malfunctioning. Quote Link to comment Share on other sites More sharing options...
stevenkeyte Posted September 27, 2023 Share Posted September 27, 2023 The wire from the sender to the engine metal was grounded, resulting in no movement seen on the gauge. Is the fuse labeled "Meter" in proper working condition? Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted September 27, 2023 Author Share Posted September 27, 2023 Indeed, the meter fuse has been verified to be in proper working condition. Quote Link to comment Share on other sites More sharing options...
stevenkeyte Posted September 27, 2023 Share Posted September 27, 2023 In the event of a malfunction in my vehicle, I would proceed with the following diagnostic steps: (1) I would proceed to momentarily establish a connection between the connector on the gauge in the cluster and the ground, while ensuring that the ignition is turned on. This action is intended to determine if the gauge exhibits any movement. (2) Subsequently, I would proceed to briefly establish a connection between the sender and the gauge in the cluster using a jumper wire. This step is undertaken to investigate the possibility of a compromised wire. Subsequently, the next step would include the pursuit of a pre-owned gauge or cluster. Quote Link to comment Share on other sites More sharing options...
