WolfieBase Posted August 7, 2024 Share Posted August 7, 2024 Greetings, everybody. Is this level of play considered acceptable? Quote Link to comment Share on other sites More sharing options...
WolfieBase Posted August 7, 2024 Author Share Posted August 7, 2024 https://cj.dotomi.com/links-t/100046867/type/dlg/sid/2518X1570512X60aa0cc25190962328fe7b7e582e0ade/https://vimeo.com/manage/videos/993679092 Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted August 7, 2024 Share Posted August 7, 2024 What is the mileage on them? When were they most last altered? Is there any oil leakage? From my inexperienced perspective, it seems to be excessive. I already changed them on my C55 a while ago, and my engine does not exhibit such much movement. Quote Link to comment Share on other sites More sharing options...
WolfieBase Posted August 7, 2024 Author Share Posted August 7, 2024 The engine remains installed on its original mounts, while the car's mileage stands at slightly under 92,000 kilometres. There are no apparent leaks when seen from above. The movement of the driver side is somewhat greater than that of the opposite side. Both parties are likely in the process of being phased out. I am contemplating replacing them with identical items, without any enhancements. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted August 7, 2024 Share Posted August 7, 2024 The amount of 92,000 dollars is likely to be over its due date. I purchased Lemforder parts for my vehicle, which are the same as those obtained from Mercedes-Benz. Various kinds of 'upgrades' are available, including non-oil filled 'polymer' options. Although I lack personal experience with these, it is important to note that the movement and vibration generated by the engine must be absorbed or redirected. In the case of solid mounts, it is likely that these forces will be transferred to the chassis. Simultaneously replace the gearbox mount. Based on anecdotal evidence, it is known that component numbers might vary for mounts that seem similar, perhaps due to the different viscosities of the oil contained therein. Uncertain 🤷♂️ Quote Link to comment Share on other sites More sharing options...
Black_raven Posted August 7, 2024 Share Posted August 7, 2024 Yes, please replace the 92,000-mile tires and also the gearbox. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted August 7, 2024 Share Posted August 7, 2024 This is an older version from Alex on C55, which is likely to be fairly similar to yours. I did not remove the exhaust as he did, maybe due to the fact that his vehicle is left-hand drive. Due to a delay in obtaining the wrench extension within the specified time frame of 1 minute and 40 seconds, I took the initiative to fabricate one. It is worth noting that the task may still be accomplished without the wrench extension, particularly while working on an M113 in a C55. The video around 12:25 seconds displays the dancing mechanism both before and after. If you decide to do-it-yourself, the engine beam is the essential equipment you need. Exclusively use authentic Lemforder components. Best wishes. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted August 7, 2024 Share Posted August 7, 2024 Quote Link to comment Share on other sites More sharing options...
WolfieBase Posted August 7, 2024 Author Share Posted August 7, 2024 Thank you everyone, I have decided to proceed with the replacement. Last year, I changed the gearbox mounts. I should have also addressed the engine mounts at that time. Quote Link to comment Share on other sites More sharing options...
