Corroded Brake Disc
stevenkeyte
Greetings, I was unwell for many days and did not operate my CX 30. We had substantial rainfall. Upon cessation, I saw that all the brake discs of the vehicle were significantly corroded. I understand it is said that driving would remove it, nevertheless thus far, little has been eliminated.Are there any methods or products available for the removal of rust from brake discs? Thank you
I would be quite reluctant to put any substances on my brake rotors. Their operation involves the friction generated between the brake pad material and the revolving steel discs. Any substance you apply would a) be rapidly removed during your next drive (together with any accumulated rust) and b) might adversely affect friction, resulting in less stopping power.
Indeed, use brake cleaner while replacing pads; nevertheless, refrain from using it for regular cleaning of rotors and pads. The substance is very corrosive, and if applied while the wheels are mounted on the vehicle, it will deteriorate the painted coatings and permanently damage the wheel finish. Furthermore, overspray may adhere to the vehicle's paint, perhaps resulting in complications. Rusted rotors after rainfall is typical and will dissipate with minor brake use during standard driving. To the original poster, you may invest significantly and get zinc-plated rotors for all wheels. Corrosion is unlikely to be an issue with them; nonetheless, you may incur significant financial loss as a result. As I already said, OP, accept it. It is typical and self-resolving with limited driving.
