2016 Sportage 1.6 left rear wheel sensor
DMGRS
I am seeing three amber warning lights indicating a wheel sensor malfunction. Carly's scan indicates that the rear left sensor is functioning intermittently.
Are there two sensors: one located in the hub and the other an insert type, as indicated by internet sources?
Thank you
Certainly - receiving codes C1207 and C1208 - left-hand wheel speed sensor - intermittent and invalid - no signal.
I am attempting to ascertain if the issue is with the round sensor in the hub or the plug-in sensor, often known as ABS sensors, which measures the rotation of the hub sensor.
Kia only sells the whole hub with the sensor for around £300+ (they are closed today).
The current ring sensor may be purchased online for around £20-30.
The inserted sensor plug-in is also available online for around £30 or more.
I hope this is comprehensible.
Have you examined the schematics in the Partsouq.com catalogue? Input your vehicle's VIN to get a comprehensive list of components, including part numbers and exploded schematics. Hyundai and Kia share several components, allowing them to be classified under either brand.
