BMW 330d E46 cooling fan!
I have just completed the front bearing installation. I started the vehicle with the hood up, and when shutting it off, I noticed the fan emitting a growling noise while decelerating. There is considerable play in the fan. Is it sufficiently clear for replacement? Would an Andante chance for a 320d constitute a straight exchange? I own one already.
Your guidance is once again valued!
Typically, BMW fans may be easily replaced by simply detaching a few clips or fasteners and removing them. The fans for petrol and diesel engines are distinct on realoem.com; thus, I conclude that it is not a straight replacement.
Thank you for that information. I will attempt to locate a tutorial video. Both vehicles are diesel; the 320d from which I removed several components, and my current vehicle, the 330d.
I will be able to compare after the old one is removed. Thank you one again.
I own a viscous clutch-driven fan connected to the water pump. I am uncertain if the issue is inside the plastic fan or the clutch component. Removal is necessary for observation. Any insights about these kind of fans would be welcomed! I have ordered a locking tool and a spanner, and I understand that it is undone by turning clockwise; that is the extent of my knowledge. Salutations
