Flexfer Posted May 26 Share Posted May 26 I have fault indicators illuminated for ABS and ESP. iCarsoft indicates malfunctioning sensors on both rear axles. Is it possible for these devices to malfunction simultaneously? The real output from the analyser is as follows: Transmission Control Module Fault 1 Engine Control Module: Fault 1 Engine Selector Module Fault1 ESP Fault1 When I access the codes, they exclusively pertain to rear wheel speed sensors as follows:Implausible speed signals from the right and left rear supplied by the traction system over the CAN bus. The right rear speed sensor for the ESP has malfunctioned. It appears peculiar that both the left and right sensors should malfunction simultaneously. The automobile is not in limp mode. Any assistance would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted May 26 Share Posted May 26 Based on my observations, the failure of one ABS sensor often precedes the failure of another. Additionally, there are the reluctor rings. Quote Link to comment Share on other sites More sharing options...
Flexfer Posted May 26 Author Share Posted May 26 Thank you for your contribution. The sensors appear to be a straightforward repair, involving testing and replacement, among other tasks. The reluctors produce a dreadful sound. Do they frequently experience failure? Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted May 26 Share Posted May 26 I can just convey my experience with my S204. I changed both front sensors approximately 500 miles apart at around 50,000 miles and the NSF reluctor at approximately 60,000 miles. Reluctors are components of the hub bearing of the 204, necessitating their replacement. Quote Link to comment Share on other sites More sharing options...
Black_raven Posted May 26 Share Posted May 26 Typically, it is the reluctor ring rather than the sensor that is at fault. My C219 has suddenly begun notifying me about tyre pressures; there are no fault codes, but the shadow memory indicates that the left sensor's height is at its limit. Both sensors and the ESP had a communication error (note: not genuine fault codes). Replacing the sensor and ring resolves the issue. Obtain live data initially, or replace the sensor/ring with one that has additional codes. From a diagnostic perspective, they are interconnected, resulting in the activation of all components. Quote Link to comment Share on other sites More sharing options...
Flexfer Posted May 26 Author Share Posted May 26 Thank you for your responses. I have detached the rear near-side sensor, and it appears to be in good condition. I inspected the reluctor ring, and it is in satisfactory shape, free from rust and other defects. I will test the sensor for resistance after I locate the connectors. Do reluctors lose their magnetism? Quote Link to comment Share on other sites More sharing options...
SD1too Posted May 26 Share Posted May 26 Enclosed with quote marks, probably as interpreted by the scanner. Quote Link to comment Share on other sites More sharing options...
SD1too Posted May 26 Share Posted May 26 Your assumption is not enclosed in quotation marks? Quote Link to comment Share on other sites More sharing options...
SD1too Posted May 26 Share Posted May 26 Attributing failure to the sensors when the scanner only displays improbable signals is unreasonable. Which does not necessarily indicate sensor failure. Do the warning lights activate upon key-on or only when the vehicle is in motion? Quote Link to comment Share on other sites More sharing options...
Flexfer Posted May 26 Author Share Posted May 26 Thank you for your interest. The quotations originate from the iCarsoft display. Upon clearing the codes, they do not reemerge until the vehicle is in motion. I removed the left rear sensor and operated the vehicle. It entered limp mode. I reinstalled the sensor, and the vehicle operated normally. The left sensor is not completely nonfunctional. I am experiencing difficulty locating the junction for the two speed sensor cables. Is it located beneath the rear seat? I am unable to locate it beneath the vehicle. Thank you once more for your assistance. Quote Link to comment Share on other sites More sharing options...
SD1too Posted May 26 Share Posted May 26 Negative - they possess no magnetism to forfeit. Their purpose is to finalise a magnetic circuit. Quote Link to comment Share on other sites More sharing options...
SD1too Posted May 26 Share Posted May 26 The symptom, if the dash warning light exhibits similar behaviour, indicates a distorted signal from the reluctor rings. May result from corroded or fractured rings, as well as tyre discrepancies in size or pressure. Alternatively, a defective brake light switch may require the application of the brake before initiating movement. Quote Link to comment Share on other sites More sharing options...
