Run-flat tires on my 3 Series
nicebubby8
My G20 is equipped with staggered wheels.
I want to replace the front tires with non-runflat variants.
The rear run-flat tires has enough tread and do not need replacement.
Is it permissible to have a combination of non-run-flat tires on the front and run-flat tires on the rear?
Install standard tires on the front and do routine doughnuts in supermarket parking lots, as well as execute aggressive starts at traffic signals. This will rapidly diminish the lifespan of the rear components, thereby resolving the issue.
