TechnoTrailblazer Posted 4 hours ago Share Posted 4 hours ago Purchased this for my son under a month ago. I already regret the purchase. Acquired from a guy who purchases and sells secondhand automobiles. Acquired on October 1st. Immediately replaced the oil due to its little contamination and excess volume.Within two weeks, we added 1.5 quarts. Recognising the issue, he is currently operating my vehicle while I determine the appropriate course of action. I purchased a new OEM PCV valve and hose after observing YouTube videos demonstrating the replacement process without removing the intake manifold. It appears that I must remove the manifold from the vehicle, as it is situated behind it, unlike the newer and previous versions. What a significant inconvenience! Do you have any suggestions? I have included two images to illustrate my circumstances. The subsequent models featuring the 2.5L engine are significantly more accessible. The entrance is indicated by the arrow on the right. Quote Link to comment Share on other sites More sharing options...
TechnoTrailblazer Posted 4 hours ago Author Share Posted 4 hours ago It appears that I was meant to introduce myself in the initial post. It is hoped that the moderator can relocate it to a more visible position. Quote Link to comment Share on other sites More sharing options...
MidnightMarauder Posted 3 hours ago Share Posted 3 hours ago In many states, it is illegal to sell used cars with specific defects. Upon identifying the issue, I would recommend contacting your Attorney General. Quote Link to comment Share on other sites More sharing options...
TechnoTrailblazer Posted 3 hours ago Author Share Posted 3 hours ago I recently discovered that someone else reported the identical issue almost one year ago. I do not remember who initiated the discussion or the precise subject line, but the final contributor proposed incorporating an inline PCV while retaining the existing one. I seek further information regarding this matter. Advantages and disadvantages Quote Link to comment Share on other sites More sharing options...
nickoyster4 Posted 3 hours ago Share Posted 3 hours ago That is simple, provided it is not jammed shut or failing to open fully. If it is jammed shut, obstructed, or not fully opening, it would be futile. Quote Link to comment Share on other sites More sharing options...
KOOLCAR Posted 3 hours ago Share Posted 3 hours ago Remove Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted 3 hours ago Share Posted 3 hours ago Does your 2010 model have the 2.5 L or the 2.4 L four-cylinder engine? Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted 3 hours ago Share Posted 3 hours ago To access the 2.5 L engine in this vehicle, it is necessary to remove the intake manifold. Is this task challenging for this vehicle? Utilise a 19 mm deep socket to remove it. It may be feasible to detach it using unconventional tools, but I am uncertain. The 2.4 L engine of this vehicle, likely the 2AZ-FE or a comparable model, is readily accessible. I believe you possess the 2.5 L. Is the removal of the intake manifold on the 2.5 L challenging? Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted 3 hours ago Share Posted 3 hours ago They merely detached a sensor and a bracket securing the cable harness, without removing the manifold. Appears to be uncomplicated? Utilising the appropriate socket length and extension, etc. It may be possible to accomplish this without removing anything except for the hose and the valve. However, the visibility is suboptimal, and you will likely need to do a laborious process initially, subsequently determining the appropriate socket, ratchet, and extension combination to remove it without disassembling more components, hence facilitating a more efficient method for future attempts. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted 3 hours ago Share Posted 3 hours ago Quote Link to comment Share on other sites More sharing options...
rab60bit88 Posted 3 hours ago Share Posted 3 hours ago I have no prior experience with this work, but I recall reading that entry is only possible through the wheel well on models from 2012 onwards. Quote Link to comment Share on other sites More sharing options...
