colinallcars Posted Monday at 10:28 AM Share Posted Monday at 10:28 AM Apologies for the redundant topic; which diagnostic tool do you recommend for Kia vehicles? I require it to reset the readings for the differential pressure sensor, among others. Thank you. Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted Monday at 10:29 AM Share Posted Monday at 10:29 AM Ultimately, the outcome will largely hinge on the specific elements you intend to reset and the financial resources you are prepared to allocate. I state this as I have lately acquired a diagnostic tool from Foxwell, after conducting considerable research. All prominent brands are manufactured in China, although they differ in the systems they permit access to or allow for reset. Upon reviewing your prior post, it appears you may already possess a diagnostic tool. Most websites provide a "compatibility" checker; however, it is essential to review the fine print to see whether it will "actuate"—that is, send instructions to the malfunctioning unit—or merely reset or eliminate the code. - often promoted as "bi-directional" I ultimately chose a Foxwell GT60, as I required a device to reset the DPF. I saved much by ordering it through AliExpress without encountering any problems. Nevertheless, it remains positioned beneath the tree; I cannot ascertain its functionality in reality. (an update will be posted!) - I initially intended to select the NT650 Elite, which is also indicated as compatible with your Carens. Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted Monday at 10:29 AM Share Posted Monday at 10:29 AM https://www.foxwelldiag.com/products/foxwell-nt650-elite?rq=mk_kia__md_carens-rp__ps_tps__yr_2016 Quote Link to comment Share on other sites More sharing options...
colinallcars Posted Monday at 10:29 AM Author Share Posted Monday at 10:29 AM Thank you. I possess an XTOOL A30M, but it lacks the required option. I was unable to locate it anywhere Quote Link to comment Share on other sites More sharing options...
nickoyster4 Posted Monday at 10:30 AM Share Posted Monday at 10:30 AM I possess one of them, but have not utilised it in a demanding situation yet. Quote Link to comment Share on other sites More sharing options...
nickoyster4 Posted Monday at 10:30 AM Share Posted Monday at 10:30 AM https://www.ukpartsdirect.com/icarsoft-cr-pro-full-system-all-manufacturer-diagnostic-tool.html Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted Monday at 10:31 AM Share Posted Monday at 10:31 AM Currently acquiring proficiency in utilising a Launch tool. Appears to be superior to my initial assessment. Initiate X431 CRP919X BT Elite Bi-Directional. I purchased it under the impression that it was an authentic UK market version. It appears that it is not, however it still looks capable of accessing the car modules and supplying extensive data. Quote Link to comment Share on other sites More sharing options...
colinallcars Posted Monday at 10:31 AM Author Share Posted Monday at 10:31 AM Can you reset the differential pressure sensor? I purchased the iCarsoft Car Diagnostic Tool CR Pro+, but it fails to reset the values, retaining the previous ones. Additionally, the peculiar aspect is that the "new" sensor displays an unusual value of -18.xx, but the old sensor registered only -0.7x, even with the ignition activated. Quote Link to comment Share on other sites More sharing options...
