Question about replacing a 12v battery
While I understand that AI isn't perfect, it did inform me that removing the 12v battery while replacing it would erase some of the memory settings. Presets, according to other sources, are saved in flash memory and will be unaffected by this. As far as I can tell, some owners have swapped out batteries without losing any of their presets. You tell me which one is right.
Can the terminals be "jumpered" to a power source during changeover to avoid losing presets if the former is true?
Additionally, even when the car is unlocked and in my garage, the red light (immobiliser?) at the top of the gas gauge on the right side of the gauge cluster blinks. I don't know why I've never noticed it before in my two years of ownership. How common is this? Many thanks
There was just one hiccup when I made the change. It is impossible for a TPMS to display tyre pressures. After many days of driving, it still hadn't worked. I had the clock set to "manual" adjustment instead of auto-GPS update, and that turned out to be the cause. I was taken aback by the connection at first, but then I remembered that each tyre pressure check is time- and date-stamped.
