vitessear3 Posted 2 hours ago Share Posted 2 hours ago Cannot get my cruise control to work. In 2022, three months after purchasing it, I began using it. I was cruising along a North Carolina motorway when suddenly, while negotiating a right-to-left curve, my cruise control dropped from 55 mph to 20 mph. I could clearly see my car in front of me, and there was nothing else in my path. Curves from the right to the left have occurred multiple times recently. Curves from left to right are not handled by it. Additionally, I have encountered a warning message approximately ten times in the past six months whenever I attempt to activate the cruise control. Smart Cruise Control is disabled, according to the message. "Radar Block" in remote places on highways and back roads where you won't see a soul for miles. There has been no one within half a mile, but suddenly the car in front of me turns white. Have you any suggestions? Quote Link to comment Share on other sites More sharing options...
vitessear3 Posted 2 hours ago Author Share Posted 2 hours ago Amazon.co.uk : cruise control Quote Link to comment Share on other sites More sharing options...
ENVIOclev Posted 2 hours ago Share Posted 2 hours ago As you may be aware, the vehicle employs a radar system to detect potential obstacles ahead. It seems like there's a glitch in that system that causes it to slow down or disable cruise control on occasion. My best guess is that it's a bad or blocked sensor. Is this the first time you've taken your car in for repairs? Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted 2 hours ago Share Posted 2 hours ago My best guess is that the radar is located in the space between the radiator and the front bumper cover. Before anything else, I wanted to make sure you hadn't been in a front bumper collision before this issue arose. It may only take a little bump into a wall or tree while parking to throw that radar off. Additionally, make sure that the area is free of any debris that could disrupt the signal, such as leaves, bugs, grit, or dirt. To rule out corrosion or excessive resistance, you could also try removing the connector from the radar module, inspecting it, and then reseating it. You can get the radar readjusted by taking it to the dealership or a collision repair shop. Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted 2 hours ago Share Posted 2 hours ago 🫠Quote Link to comment Share on other sites More sharing options...
another_clean_sheet Posted 2 hours ago Share Posted 2 hours ago When you're driving on a curve, the object that appears "straight ahead" to your car's Smart Cruise Control could be anything from a sign to a bridge abutment or guardrail. If your system is calibrated correctly, it should be able to tell the difference between these immobile objects and the car you are about to rear-end. But it can get confused if the sensor is even slightly misaligned. This would clarify why it solely occurs on one-way curves; the geometry is precisely correct for the radar to detect an anomaly that it shouldn't. A related but distinct symptom is the appearance of a ghostly vehicle on your screen. If the system is unable to receive a dependable signal, whether because of an external obstacle like bugs or an internal malfunction, it will display the "Radar Blocked" message as a kind of surrender. This task should be handled by the dealership, as your vehicle is a 2022 model. As part of the warranty on your new car, they should be able to recalibrate the sensor and diagnose the problem. Give them a chance to figure it out before the system slams on the brakes for that unusual mailbox. Quote Link to comment Share on other sites More sharing options...
