stevenkeyte Posted September 18, 2023 Share Posted September 18, 2023 The 2019 CX-5 GT model is equipped with the Homelink feature. The garage door opener in question seems to be a Craftsman type that is estimated to be around 15 years old. It is equipped with a battery backup feature, which is still functional, suggesting the possibility that it may be a newer model that was installed by a prior owner. In spite of having perused the handbook and seen instructional videos, I have encountered difficulties in successfully implementing the desired functionality. Initially, it is unclear as to why certain instructions suggest parking the vehicle in an outdoor location, unless this provision was devised by legal professionals as a precautionary measure in the event that an individual, due to their lack of awareness, inadvertently activates the door while adhering to this procedure, potentially causing harm to individuals or objects in its descent. To clear codes, it is necessary to press and hold buttons 1 and 3 until a fast blinking pattern is seen. To start the process, position the transmitter button at a distance of 2 inches and simultaneously press and hold button 1. Proceed to wait until a noticeable alteration in the blinking pattern occurs, characterized by a quick succession of blinks. To activate the door opening mechanism, please press the homelink button twice. It is important to note that in the case of a rolling code opener, the door may not open as anticipated. To initiate the learning process, the user should locate and depress the learn button, which is situated at the bottom of the door opener in the garage. Upon activation, a yellow light will illuminate on the opener. To initiate the desired action, it is recommended to engage the homelink button for a duration of 2 seconds, followed by a release, within a time frame of 30 seconds. This process should be repeated once more to ensure proper execution. The light on my garage opener exhibited a brief flashing behavior during the first two seconds of activation. Subsequently, no more response or action was seen, and repeated attempts to operate the garage opener using the Homelink button were unsuccessful, even after holding it down for a third or fourth time. I have come upon a video. According to the instructions, it is recommended to push the Homelink button three times without holding it for an extended period. This approach also proves ineffective. It is plausible to suggest that step 5 shown in the video may be erroneous. In Step 5, no discernible action occurs. However, an alternative approach involves pressing and holding the Homelink button, resulting in the illumination of the light on the garage opener after a brief delay of around 2-3 seconds. Subsequently, I proceeded to depress the Homelink button on three separate occasions, although no discernible outcome ensued. Upon pressing and holding the Homelink button, no further action is seen save for a quick blinking. There exists a device known as a "bridge" that may be purchased in order to facilitate the use of certain openers. Nevertheless, it seems to me that if the Homelink button elicits a flashing light from the opener, then it is indeed engaging in communication. Consequently, I would surmise that the inclusion of a "bridge" may not be essential in this scenario. However, I am unable to achieve the desired functionality. I have attempted almost all conceivable combinations, including the omission of step 3, as well as the execution of a single press-and-hold action throughout step 3. During a particular instance, the garage opener exhibited a second blinking occurrence upon my second or third sustained push while in learning mode. However, despite this observation, the garage opener ultimately failed to function as intended. I am now experiencing a significant level of frustration and exhaustion with this matter. If the presence of a bridge is not deemed necessary, the only plausible explanation I can now provide is that the inability to completely sever the power connection to the receiver during the first programming of the button, owing to the presence of a battery backup, would trigger the activation of the 'rolling code' function, causing the Homelink system to see it as an unfamiliar transmitter. However, I am skeptical of this claim, since the presence of the "Learn" button should render the aforementioned concerns irrelevant. In essence, it should temporarily deactivate the security feature associated with the rolling code mechanism in order to facilitate the learning process of the Homelink button. Quote Link to comment Share on other sites More sharing options...
HOV Posted September 18, 2023 Share Posted September 18, 2023 Our residential property is equipped with an overhead door garage door, and we encountered difficulties while attempting to operate it using a portable transmitter. The learn button on the opener was exclusively used, followed by a 2-3 second press of the homelink button. Subsequently, the homelink button was pressed three further times, resulting in a successful programming outcome. Quote Link to comment Share on other sites More sharing options...
norbury.brook Posted September 18, 2023 Share Posted September 18, 2023 I am grateful for your assistance in achieving cost savings by avoiding the engagement of a professional garage door repair specialist. The process of programming the Homelink button with the above garage door may be accomplished with ease. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted September 18, 2023 Share Posted September 18, 2023 Have you have any success in making it operational? I have had two instances with Mazdas where I faced difficulties in training the Homelink system, which has been a source of frustration for me. I exhibit identical behavioral patterns to those which you have described. The illumination intermittently flashes after to the first actuation and subsequent sustained depression and release, although no further response is seen thereafter. Quote Link to comment Share on other sites More sharing options...
HOV Posted September 18, 2023 Share Posted September 18, 2023 No, we were unable to achieve effective programming of it. Quote Link to comment Share on other sites More sharing options...
stevenkeyte Posted September 18, 2023 Author Share Posted September 18, 2023 I too had difficulties in achieving functionality with my own device. I reached out to a Garage Door firm listed on Yelp, which had shown their willingness to provide assistance. However, I refrained from engaging their services as I possessed a high level of certainty that I had exhaustively attempted all conceivable approaches to resolve the issue. One intriguing observation was that on some occasions, the conventional opener had difficulty in functioning properly when positioned directly in front of the door, even when equipped with fresh batteries. Consequently, it needed many attempts, often ranging from two to three pushes, to achieve the desired outcome. It is possible that the unit exhibited malfunctioning behavior, leading to intermittent instances when it erroneously prevented both the Homelink and the real opener from functioning properly. This might be attributed to a potential misinterpretation of both devices as unauthorized scanning efforts, although this remains speculative. However, it is important to acknowledge that my idea may be speculative and lacks substantial evidence. It is very probable that the following information is pertinent to Craftsman users who are experiencing difficulties with their homelink functionality. The HomeLink Compatibility Bridge Kit is a product that enables the integration of HomeLink technology with various home automation systems. After relocating, I found that the homelink button on my vehicle functioned well with the new garage opener at my new residence. Quote Link to comment Share on other sites More sharing options...
torque2me Posted September 18, 2023 Share Posted September 18, 2023 I had a similar issue and was on the verge of experiencing significant frustration. Ultimately, I successfully reset the opening mechanism and cleared all associated remote controls. The process was then started again. The system operated smoothly and executed according to its intended programming. The only concern was to the need of reprogramming all interconnected components. It is essential to establish a constraint on the quantity of remote controls that may be accommodated. Quote Link to comment Share on other sites More sharing options...
stevenkeyte Posted September 18, 2023 Author Share Posted September 18, 2023 The proposed approach of a comprehensive reset path is intriguing; but, however, I am unable to evaluate its effectiveness since I have already resolved the issue by relocating to a different residence. The user expresses amusement through the acronym "LOL." Quote Link to comment Share on other sites More sharing options...
