xsports Posted August 6, 2024 Share Posted August 6, 2024 The sound of the Cx90 resembled that of my father's 1960 Bel Air. A service bulletin has been issued and parts have been ordered. Quote Link to comment Share on other sites More sharing options...
MidnightMarauder Posted August 6, 2024 Share Posted August 6, 2024 Certainly, could you kindly provide the service bulletin? It seems that there is currently no solution available for this issue in Canada. Thank you Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted August 6, 2024 Share Posted August 6, 2024 Could you kindly provide the bulletin or specify the specific portion you are referring to? I have a scheduled appointment next Monday just for addressing the same problem. Quote Link to comment Share on other sites More sharing options...
ElectricEclipse Posted August 6, 2024 Share Posted August 6, 2024 This is the most recent Technical Service Bulletin (TSB) that includes the addition of dust covers. I am uncertain about the availability of this TSB in Canada. In September, my dealer applied lubricant to the source of the squeaky noise, and since then, the problem has not reoccurred. Anomalous noise emanating from the front of the vehicle while encountering a bump while executing a turn at a low velocity. M R TSB Number: R017/23, dated March 25, 2024, regarding PD CX-60. Until August 1st, 2023, the CX-90 is available. Until July 20th, 2023. Problem: Anomalous noise (creaking, squeaking) emanating from the front of the car after encountering a bump when making a turn at a slow speed. The reason: A stick-slip phenomena may happen between the front stopper rubber and the bracket in the front lower rear arm. Refer to TSB. The solution involves doing a thorough examination, performing tests, and making precise adjustments to ensure proper clearances. Additionally, fresh grease will be applied, and the dust covers will be replaced with new ones, even if they are not necessarily required. Modification in the process of mass production    The stopper rubber has been lubricated with grease.    Lower arm dust coverings have been inserted.    The size of the mounting hole on the lower arm bracket has been altered. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted August 6, 2024 Share Posted August 6, 2024 Expressing gratitude! Quote Link to comment Share on other sites More sharing options...
ElectricEclipse Posted August 6, 2024 Share Posted August 6, 2024 I discovered an alternative Technical Service Bulletin (TSB) on the website of the National Highway Traffic Safety Administration (NHTSA). Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted August 6, 2024 Share Posted August 6, 2024 Excellent, this is quite helpful. I will bring these items to the service appointment with the expectation of receiving prompt and efficient assistance, without encountering any unnecessary delays or complications. Expressing gratitude! Quote Link to comment Share on other sites More sharing options...
ElectricEclipse Posted August 6, 2024 Share Posted August 6, 2024 has been shared earlier by user cx90mc. Quote Link to comment Share on other sites More sharing options...
