Lockless entrance system
rab60bit88
What's up? For 2020, I have a CX-30. Install keyless entry sensors in the form of square markings on the door pull handles. However, the doors don't unlock in my vehicle when I touch them. Well, I think I have keyless entry anyhow. I'm hoping you can provide a hand; maybe there's a menu choice on some diagnostic machinery that I need to enable this feature on.
You don't have keyless entry if your door handles don't have a depression to indicate where the sensor will be located (and which ones are used to lock the vehicle). Can I start it with a button press? If so (I'm never sure of regional differences), you could also have keyless entry. Keyless entry is not possible without a push-button starter.
In Canada, it is observed that all CX-30 vehicles has identical door handles with an indentation. However, it is worth noting that only the highest trims, namely the GT, provide the feature of sophisticated keyless entry. This feature allows the user to conveniently lock the vehicle by pushing a button and unlock it by pressing a button located beneath the handle. All Mazda CX30 vehicles at this location are equipped with a standard keyless entry system, which utilises buttons on the key fob, along with a push button start feature.
