KWILB Posted October 7, 2024 Share Posted October 7, 2024 Can somebody disclose the position of the vehicle speed sensor? I verified the vehicle's speed; it is fixed at 50 mph. Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 7, 2024 Share Posted October 7, 2024 The signal will be sent from the ABS sensors via the DSC module across the CAN network. Assume that all other speed indicators, such as the speedometer, are functioning properly? Quote Link to comment Share on other sites More sharing options...
KWILB Posted October 7, 2024 Author Share Posted October 7, 2024 The speedometer is functioning; nevertheless, the steering light is on, and steering has become difficult. Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 7, 2024 Share Posted October 7, 2024 If the DSC is generating a speed indication, I would suspect a malfunction in the EPS control module. I presume there are no recorded CAN communication faults? Quote Link to comment Share on other sites More sharing options...
KWILB Posted October 7, 2024 Author Share Posted October 7, 2024 Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 7, 2024 Share Posted October 7, 2024 It seems you may have a problem if the SAS is not interfacing with the stability control, since I anticipate the speed signal will traverse the same network. Consider it the conclusion of the FlexRay bus. Which automobile is it? Quote Link to comment Share on other sites More sharing options...
KWILB Posted October 7, 2024 Author Share Posted October 7, 2024 It is a 2006 facelift model of the Z4 2.5. Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 7, 2024 Share Posted October 7, 2024 In that scenario, I am rather certain that the rack on the Z4 is a frequent cause of steering angle issues and loss of speed signal owing to the failure of the torque sensor. Quote Link to comment Share on other sites More sharing options...
KWILB Posted October 7, 2024 Author Share Posted October 7, 2024 Could you kindly indicate the position of the sensor? Quote Link to comment Share on other sites More sharing options...
KWILB Posted October 7, 2024 Author Share Posted October 7, 2024 Should I disassemble the steering column? Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 7, 2024 Share Posted October 7, 2024 It is located inside the rack, necessitating the removal of the rack and subsequent access. Quote Link to comment Share on other sites More sharing options...
