heralder Posted October 9, 2024 Share Posted October 9, 2024 I have replaced my tires. The dashboard indicated no faults upon departure; but, after five miles, the amber light began to strobe and is now continuously on. Inspected the tires and restored them to standard pressure of 35 psi, then activated the set button located in the glove compartment. The light remains illuminated; do you have any recommendations? Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted October 9, 2024 Share Posted October 9, 2024 Did the tire shop manipulate or replace the TPMS sensors? Quote Link to comment Share on other sites More sharing options...
Ken_Lion Posted October 9, 2024 Share Posted October 9, 2024 Did you push and hold the reset button until the TPMS light flashed three times? Quote Link to comment Share on other sites More sharing options...
rab60bit88 Posted October 9, 2024 Share Posted October 9, 2024 Perhaps grasping at straws, but did you let it to remain for an hour before adjusting your pressures? It is advisable to establish them in a chilly state. Continuously monitor for any authentic air loss, since it may occur during a tire replacement if there is rust on the rear of the rim obstructing a proper seal. Quote Link to comment Share on other sites More sharing options...
heralder Posted October 9, 2024 Author Share Posted October 9, 2024 I appreciate your recommendations. In summary I have waited for three hours after my return, verified the tire pressures and confirmed they are accurate at 35 psi with no air loss. I am uncertain if the tire facility caused any damage to the TPMS sensors, which I presume are located inside the tire valves. Could someone verify the location of the TPMS sensors? Upon starting the vehicle, the yellow light blinks many times before becoming on. I restarted the vehicle and pressed the reset button centrally for many seconds, nevertheless the light continues to flash. I intend to return it to the tire shop tomorrow unless there are superior recommendations. Thank you. Quote Link to comment Share on other sites More sharing options...
bentleygt77 Posted October 9, 2024 Share Posted October 9, 2024 TPMS sensors are located inside the rim. Utilising an Autel or Toyota Techstream, they should be capable of diagnosing a defective TPMS sensor. However, they may need to experiment with the wheels and the distance from the automobile to ascertain whether component is really defective. If replacement of a sensor is necessary, get an original component rather than an aftermarket part. Pattern components are often unreliable, resulting in superfluous warnings every several months. Â Quote Link to comment Share on other sites More sharing options...
Starcar2022 Posted October 9, 2024 Share Posted October 9, 2024 Is it necessary to drive the vehicle for a short period after the reset? Quote Link to comment Share on other sites More sharing options...
nicebubby8 Posted October 9, 2024 Share Posted October 9, 2024 If all sensors are discovered, you should be able to identify their serial numbers. If you possess the numerical data, you may also program it using Carista. The Carista app offers a 15-day trial period. However, at this moment, you ought to return to the tyre stores. Reprogramming is unnecessary if just the tires are changed. It is quite probable that they disable the sensors, rendering them inoperative. I replaced the tires twice and did not need reprogramming. Resetting is necessary only if you own entirely distinct setups for winter and summer. Auris models from 2015 or after can accommodate two sets, however earlier models need reprogramming each time the sets are changed. Quote Link to comment Share on other sites More sharing options...
nicebubby8 Posted October 9, 2024 Share Posted October 9, 2024 The Carista App is compatible with any fully functional ELM327 OBD2 scanner. Quote Link to comment Share on other sites More sharing options...
nicebubby8 Posted October 9, 2024 Share Posted October 9, 2024 https://priusapp.com/obd.html Quote Link to comment Share on other sites More sharing options...
EnchantedScribe Posted October 12, 2024 Share Posted October 12, 2024 great thank you Quote Link to comment Share on other sites More sharing options...
