Which gasoline brand do you use?
vitessear3
I'm now filling up with Shell's V Power unleaded fuel, which is meant to perform better than regular unleaded fuel and has a 99 RON rating.  But there are also Texaco with Techron, BP Ultimate, Tesco Momentum (99 RON), Total Excellium, and Tesco Ultimate.
Since store petrol is allegedly terrible, I only ever purchase from Texaco, Total, Shell, BP, or Esso.
Therefore, I want to know whether these premium fuels are superior to your average 95/97 RON and if there are certain manufacturers that are better than others.
I own a Mazda6 TS2 2.0l petrol (the cap specifies using no less than 95 RON).
I would not squander my money on premium Mazda 6 gasoline. As I noted in previous article, it's not a high-performance vehicle, therefore regular gasoline will suffice. I doubt you'll notice a change in performance, but you will see a difference in your wallet.
However, it seems that performance is not the only factor.  There are cleaning compounds in premium fuels that assist maintain clean injectors, and I've heard that the higher RON level may reduce engine banging.
The cheaper fuels are nice on the wallet, but I can't help but wonder whether it's worth it to spend a few additional pounds per tank to have better short- and long-term performance.
I try to use Shell fuel; I'm not sure if it is superior to the competition, but it seems to work well with the vehicle. I don't always use V power; however, when I had the 3MPS, I had to use it in that and if I didn't, there was a noticeable drop in power, but then again, that is probably because it is a performance vehicle. I'm not sure if it will make much of a difference to the 6 2.5, but I will try
I'm using the cheapest supermarket petrol I can find, as recommended by the dealer. According to the book, these engines are designed to operate on 90 RON in areas like Vietnam. During its first year, my automobile is presently averaging slightly under 40 mpg. There are no issues.
I'm sorry, but I have to disagree with those that use ultra-cheap gasoline. About six weeks ago, when I initially acquired my automobile, I noticed that it was slow to start up with a warmish engine.After three gallons of Shell's premium gas, the issue disappeared.Keep in mind that the fuel system might benefit from the cleaning chemicals included in high octane fuels. After filling up my tank a second and third time with premium gasoline, I plan to go back to the regular fuel. To the best of my knowledge, automobiles exported to nations with lower RON standards are already configured to function properly on the lower quality fuel. What about grocery store items?
Can only say as I find it, I have ran on supermarket diesel and gasoline from the middle of the 1980s. Most cars went one hundred thousand miles before needing a change after four years with no issues.All offered in excellent working condition..
I believed that the "premium" brands and supermarket goods were produced in the same refineries.
Everything originates in the same hole in the ground and is processed via the same refineries and distribution ports. It is the chemicals used by companies like Shell that aid with system lubrication and injector cleaning that make the difference. Shell garages are usually the cheapest in the nation, in my experience. You also earn a cent or two back per litre with a Shell rewards card - no contest.
I have also discovered that the fuels sold in supermarkets produce more foam than the fuels sold by oil firms such as Shell, BP, and others. I'm going to guess that it's the additives that aren't sold in supermarkets. My go-to brand of gasoline is Shell, which is often the least costly (oops, I meant cheaper!!) in this area
