Refurbishment of Headlamps
KOOLCAR
I am preparing to sell the CLK convertible, and the headlight covers need refurbishment to eliminate the clouding prior to the sale. I am apprehensive about using a power tool due to the potential for poor execution; but, I found the manual method of sanding with increasingly finer sandpaper and T-cut to be rather laborious on my previous attempt. While searching for a kit for the task on eBay, I discovered this:
We apologise for the disruption...
I believe that a small sander/polisher pad attached to a cordless drill would be enough, since I could precisely regulate the drill's speed. I am quite apprehensive about achieving a uniform application of sealer thereafter.
I also discovered this:
I have never encountered something like. No use instructions are provided; nonetheless, it is evidently a disposable item from ShenZhen intended for sealer application. Is it potentially ineffective? Has anybody used a similar device? Is it satisfactory?
