Locate the dash cam fuse for the 2024 Sportage
Rudy7831
Hi, I'm sure someone has already answered this, but I can't seem to locate a thread that specifies which fuses my DashCam needs. My dash cam won't turn off, and parking mode is disabled, so I began by adjusting the battery and multimedia settings for acc. People have used different fuse placements. For your information, I have included a copy of the fuse box layout.
The fuse layout design is attached; however, could you please specify the locations on the diagram you are utilising for acc and b+? I will disable parking mode after hearing your story and because I experienced a similar issue with another camera. The dealer replaced the battery once I convinced them to do so, but I had always assumed that parking mode was to blame.
