Rudy7831 Posted 1 hour ago Share Posted 1 hour ago Hi, I'm sure someone has already answered this, but I can't seem to locate a thread that specifies which fuses my DashCam needs. My dash cam won't turn off, and parking mode is disabled, so I began by adjusting the battery and multimedia settings for acc. People have used different fuse placements. For your information, I have included a copy of the fuse box layout. Quote Link to comment Share on other sites More sharing options...
migueldosantos77 Posted 1 hour ago Share Posted 1 hour ago One of the spare fuses is an accessory that turns on just when the engine is turned on, and I utilised the other spare, which is a permanent 12-volt, to power everything. Quote Link to comment Share on other sites More sharing options...
migueldosantos77 Posted 1 hour ago Share Posted 1 hour ago One of the spare fuses is an accessory that turns on just when the engine is turned on, and I utilised the other spare, which is a permanent 12-volt, to power everything. I haven't had any issues with the battery warning since I changed mine from 24-hour recording to recording only when the car is hit. Quote Link to comment Share on other sites More sharing options...
Rudy7831 Posted 1 hour ago Author Share Posted 1 hour ago The fuse layout design is attached; however, could you please specify the locations on the diagram you are utilising for acc and b+? I will disable parking mode after hearing your story and because I experienced a similar issue with another camera. The dealer replaced the battery once I convinced them to do so, but I had always assumed that parking mode was to blame. Quote Link to comment Share on other sites More sharing options...
migueldosantos77 Posted 1 hour ago Share Posted 1 hour ago I will snap a picture of my wiring after Mrs. returns from taking the car. A hardwire kit was purchased for my gku dashcam. My battery's positive terminal is yellow, and the red wire is an accessory. Quote Link to comment Share on other sites More sharing options...
Rudy7831 Posted 1 hour ago Author Share Posted 1 hour ago Okay, I understand. Contrary to yours, my vantrue dash cam and hardwire kit has a yellow acc and a red battery (b+). Quote Link to comment Share on other sites More sharing options...
migueldosantos77 Posted 1 hour ago Share Posted 1 hour ago Connected directly to the body, my components are on fuse 6, which is for accessories, and fuse 9, which is for battery positive. Used the companion app to adjust my dashcam's parameters. Quote Link to comment Share on other sites More sharing options...
migueldosantos77 Posted 1 hour ago Share Posted 1 hour ago https://www.startmycar.com/gb/kia/sportage/info/fusebox/2024 Quote Link to comment Share on other sites More sharing options...
Rudy7831 Posted 1 hour ago Author Share Posted 1 hour ago What a blessing you are. The first time around, it was a breeze. Your patience and support have meant the world to me. Enjoy the rest of your day! Quote Link to comment Share on other sites More sharing options...
migueldosantos77 Posted 1 hour ago Share Posted 1 hour ago Feeling relieved that it was successful Quote Link to comment Share on other sites More sharing options...
