Complete-sized spare tire and jack
DMGRS
Ebay is likely your optimal choice for full-sized wheels and tires. A high-quality hydraulic jack effectively elevates the vehicle, yet it will significantly reduce trunk capacity and add considerable weight to transport.
I purchased a space saver and jack from https://www.thewheelshop.co.uk/. It functions effectively and prevented me from being stranded when I experienced a flat tyre recently.
I possess a GT Line S, and currently, obtaining tires is challenging; therefore, I have a new one at home, prepared for use if necessary…
I possess a space saver wheel and kit acquired from The Wheel Shop. It accommodates the available space beneath the floor exceptionally well (once the polystyrene insert has been removed). Any of the equipment currently present can be repositioned in multiple locations, including within the new spare tire.
Yet another contented patron of the wheelshop has arrived. I suggest acquiring the kit that contains a jack. I intended to repurpose the jack from my compact Yaris, but the disparity in weight is excessive. The ratchet handle on the wheelshop jack is significantly more user-friendly than the conventional bent rod variant.
