Driving mode
bl52krz
Hello, I just acquired the vehicle today, so I might be overlooking something obvious; is it possible to configure the drive mode to remain permanently set to "eco," even after the car is turned off? Consider that the default setting is intended to be standard, yet I consistently observe it in both sport and normal modes upon powering on and off.
I have not discovered a method for accomplishing it. One might assume that it would be saved in your profile alongside any other preferences you have established, unfortunately, this is not the case. If anyone possesses superior knowledge, I would be eager to learn.
I apologize; I have just verified your statement, and you are correct, which has left me feeling discontented. 🙂
The conduct of my Soul indicated that it preserved the configuration. There was a singular instance when it malfunctioned, and I was unable to discern the reason; however, I resolved the issue by restarting the infotainment system. The indicators were that it failed to retain the regeneration level. Since the regeneration level is sustained on the EV2 and EV3, I presumed that the eco mode was also preserved. (cue remarks on presuppositions rendering one foolish etc)
The Soul featured a configuration menu that enabled customization of the functions associated with each drive mode. Furthermore, the application possessed a significantly broader array of adjustable parameters compared to the present.
In software development, particularly regarding the management of physical devices, incorporating additional features often compromises testing complexity and duration - simplicity typically prevails.
The BYD application consolidates all essential features on a single page. Provides you with the most recent information regarding the opening. The page does not refresh to display the most recent date.
Customer services and breakdown assistance can be accessed from a single page.
All concealed elements are merely sub, sub, sub menus. 🤣 that are perpetually elusive.
