MDMH757 Posted October 22 Share Posted October 22 The 2015 E350 212 estate has almost 120,000 miles on the odometer. I used to get it serviced at MB as part of my service plan, but when the price of the plans went up a few years ago, I switched to a local indie. They aren't experts in MB, but they've been able to fix most of the things I couldn't handle on my own. The car was serviced and MOTd a few months ago without any problems; however, I had observed that the rear suspension had a tendency to dip when parked for an extended period, so we decided to have someone check it out. I started to notice an issue every once in a while while driving around the same time. While in sixth or seventh gear, it became the most apparent. When you gently press down on the accelerator after coasting for a while, you might feel a little 'kangaroo' effect, similar to what you would experience in a manual gearbox car when you're going too fast for the gear you're in. At the time this problem was discovered, the vehicle was not shifting gears. Took the vehicle in for a suspension checkup; after discovering a leaking air spring, the issue was resolved. In their investigation into the kangaroo problem, they uncovered a gearbox code reading "Internal control fault at the CPU" (P060C-00). They were able to clear the code and then had the vehicle for a few days, during which time they took it for multiple test drives without noticing any problems and the error code never came back. But, I've observed that the problem appears to persist even now. Icarsoft did a scan, and it came up error-free. Additionally, I have reset the gearbox twice, but the problem persists. Not constantly, but generally speaking, the vehicle performs admirably. I could probably handle it if it wasn't going to get worse or if it wasn't an indication of some kind of impending catastrophe, but it's also not like this before and it's not normal. I would greatly appreciate any recommendations that members may have before I return to the independent, with whom I have maintained a cordial relationship throughout the years and with this vehicle in particular. Giving it to the neighbourhood MB dealer is no longer an issue for me. I was never impressed by their service, and after just a few days I would have racked up a bill that was more than the car was worth! Quote Link to comment Share on other sites More sharing options...
DreamCatcher88 Posted October 22 Share Posted October 22 Were you able to resolve this? Like you, I've experienced severe kangarooing, particularly at low throttle. It turns out I needed to clean the MAF sensors, which fixed the problem for around three months before I had to do it again. Maybe I'll switch them out someday. Quote Link to comment Share on other sites More sharing options...
Ken_Lion Posted October 22 Share Posted October 22 He may miss your post since he hasn't been on this site since April. Quote Link to comment Share on other sites More sharing options...
DreamCatcher88 Posted October 22 Share Posted October 22 Much obliged, sir. I solved my kangaroo problem by thoroughly cleaning my MAF two months ago, but now I'm beginning to doubt my MAF situation. There it is again. At light load, when other systems are beginning to function, the air-fuel mixture is most sensitive, which occurs between 1300 and 1500 revs. I'm assuming that in 8 or 10 weeks, they will be just as shoddy because of all the oil vapour that is reaching them? The PCV valve has already been replaced. Do you know that even a small amount of oil can produce a lot of vapour? Quote Link to comment Share on other sites More sharing options...
