Feeling let down!
bl52krz
I went to Hendy Bournemouth last Wednesday in my '23 Niro4 EV. I asked the astute Master Tech to inspect the charging "brain" of the traction battery while I was there because I needed to replace the reversing camera (apparently, the lens gets misted up often). After resetting everything, he verified that the SOH was at 100%. The vehicle is significantly less fuel efficient than my eNiro4+ (2021), which is why this is the case.
I ran a test over the weekend. The email I sent to the Techy is attached below.
We need to know how many other people who bought Niro EVs from Kia are also dissatisfied.
Just wanted to let you know that they switched up the NiroEV's software and motor suppliers.
Between 4.5 and 5.5 is the eNiro Normal MpKw. The Niro EV has a factory figure ranging from 3.5 to 4.5. No matter how hard I try, I can never get a 4. I depend on the seat and steering heel and always drive in Eco mode; I never turn on the heating.
The 2023 model is Korean-made and has shoddy construction compared to the eNiro. Each of them has a heat pump.
I will email Kia about this, but I am prepared to be completely embarrassed. The Sportage PHEV is another vehicle I'm thinking about trading in. If anyone here has one, could you please tell me the actual gas mileage and the actual distance travelled while only using an electric vehicle?
In any case, Kia might be saying goodbye for good.
Yours truly.
Hello, Colin.
**My dear**, I was hoping you might find the numbers from the most recent charge interesting.
12/11: 260 miles go to 100% charge. 15/11: 168 miles since charge. We left Sherborne at 149.
Reached Poole at 101 GOM ——— 48 miles away.It's a loss of twenty percent! Wow, that's incredible!
Using regen whenever possible, no heated seat or wheel.
I got home (with a hot battery) at 12 degrees Celsius and 14.50 ETF 22, so obviously the temperature will drop significantly by the time we finish. I charged it right away.
Miles and 100% are set.
Chat GPT (Providing all car details) estimated a 2.5% mileage penalty for my Falken Euroall Season AS210 (195/60 R15 88H) tires. Considering the design and structure of the tires.
This is absolutely terrible, in my opinion! Is bringing this up with Kia going to accomplish anything?
After all, we did cover the fact that the eNiro picked up 5 miles on the way from Poole to Sherborne*.
I would never have traded in what I thought was going to be a better model for Kia if I had known they would ruin the performance.
What a squandering of funds!
I wish you the best,
Hello, Colin.
Strangely enough, I upgraded from an Eniro to a Niroev 2023 and saw an overall improvement in mileage and performance. It appears that the more recent EV models are unable to achieve the same. You can manually pull down the statistics by plugging in an ODB.
