QuirkyPixel Posted 20 minutes ago Share Posted 20 minutes ago I typically go on shorter trips in my 2024 1.6-liter manual Sportage. So far, I've had to get three regens done at the garage. It would be helpful to know if my current strategy of blasting at high revs and then decelerating once a week is keeping the warning light away. Have read about people utilising OBD readers to assess the severity of soot buildup on this site. I need to know if these won't void my car's warranty or if they're safe to use on my vehicle. This vehicle is a mobility vehicle. By the way, are they effective? If they do, could someone recommend one for a specific vehicle? I've heard that some are incompatible. Looking for some advice on this. I am grateful. Quote Link to comment Share on other sites More sharing options...
QuirkyPixel Posted 19 minutes ago Author Share Posted 19 minutes ago https://www.amazon.com/s?ascsubtag=v1-7e312b-90968-5cab022f0d-k&k=ppf Quote Link to comment Share on other sites More sharing options...
KOOLCAR Posted 19 minutes ago Share Posted 19 minutes ago For 8,000 miles, mostly on local journeys, I had the same Sportage as you and never had a problem with ppf. The vehicle can refuel on its own! When it doesn't work, all you have to do is follow the cleaning procedure. When you press down on the accelerator, the engine releases enough oxygen to clean the filter. To account for this, I modified my driving style such that I pressed down on the accelerator whenever possible on downhill sections of road and on dual carriageway/motorway slip roads (of course, only when it was safe to do so). As you begin to look around, you'll notice that all of the roads have gentle downhill slopes. To make the cleaning process easier, take a short 3- to 5-second break. I was successful! Using an obd reader is a breeze; they don't alter anything; just take them out before a service, and no one will suspect a thing. Quote Link to comment Share on other sites More sharing options...
KOOLCAR Posted 19 minutes ago Share Posted 19 minutes ago ANCEL AD310 OBD2 Scanner Code Reader Car Engine Fault Diagnostic - Orange | Classic Auto OBD Scan Tool Enhanced Read and Clear Error Codes for Most 1996 or Newer OBDII Protocol Vehicle : Amazon.co.uk: Automotive Quote Link to comment Share on other sites More sharing options...
QuirkyPixel Posted 18 minutes ago Author Share Posted 18 minutes ago The response is appreciated. For the PPF to function properly, it appears that I will need to make some adjustments to the way I drive. It is encouraging to hear that it met your needs. When it gets in the way of you safely operating the vehicle, I still think it's a poor design. Installing a sensor that indicates the PPF's level would be a great addition by Kia. Comparable to the tyre pressure monitors Quote Link to comment Share on other sites More sharing options...
trikey Posted 18 minutes ago Share Posted 18 minutes ago accurates my assessment; I also believe that many people with blocked PPF syndrome have not followed the recommendations to a logical extent since they are unable to unblock the filter. Unfortunately, many people still buy into the nonsense said on car forums about how the "Italian tune-up" is the magic formula for perfect driving conditions, even though it's hard to find good roads that allow one to follow the rules. While it might clear the DPF in some diesel models, it won't work in petrol ones. Even though it has worked in most cases, the problem is that many people either can't or won't change their driving habits. If I had to guess, I'd say that many people's fear of losing control when approaching roundabouts or other situations requiring them to slow down is the biggest problem with petrol and MHEV cars. Perhaps you've been in a situation where you were about to enter a roundabout when you noticed that the cars behind you were braking late and hard instead of doing the completely sensible thing and either not braking at all or braking earlier so that you didn't have to use as much brake pedal effort. For some reason, many drivers have a deeply held belief that they are entitled to drive recklessly for as long as they want, regardless of traffic conditions. This belief likely stems from the day they passed their driving test and has persisted ever since. Putting that aside, you've probably figured out that the blocked filter problem is due to a technological defect; as a result, manufacturers can bury their corporate heads in the sand, leaving owners high and dry as the automakers evade the recall requirement. Maybe there aren't that many complaints compared to what we see in online car forums, or maybe the Ombudsman and motoring groups aren't effective enough to warrant any kind of action from Hyundai or KIA. Quote Link to comment Share on other sites More sharing options...
QuirkyPixel Posted 17 minutes ago Author Share Posted 17 minutes ago It is challenging to do the continuous acceleration and deceleration scenario if you do not reside near an open stretch of road, as you correctly pointed out. Doing the foot-down-then-off-for-5-seconds thing for twenty minutes in the car on a drive might be effective, I wonder. My two cents on the matter Quote Link to comment Share on other sites More sharing options...
trikey Posted 17 minutes ago Share Posted 17 minutes ago Here's the question for you: was KIA the one who came up with the methodology described in earlier pages of this forum? It's worth keeping in mind. I believe KIA would have made note of it if it had been thought it could be accomplished by just starting the engine and increasing the revs, etc., as described. Quote Link to comment Share on other sites More sharing options...
HOV Posted 16 minutes ago Share Posted 16 minutes ago Without putting too much strain on the engine, I doubt you'll be able to heat the filter to a point where cleaning can begin. To begin, you must heat the filter to a certain point; then, by adding oxygen, the temperature is raised even further, much like blowing on fire embers, in order to clean the filter. Quote Link to comment Share on other sites More sharing options...
