Engine replacement
paulh2602601
I own a 2012 V10 motorcycle equipped with a blown motor.
A V10+ motor manufactured in 2014 has been found. I would want to inquire whether anybody is aware of the feasibility of this.
Is it necessary to replace the ECU? Any potential complications that may arise when a new motor is introduced into a gated automobile, such as an automatic gearbox. We really value any feedback.
According to the information provided, it is necessary to replace the instrument cluster for the immobiliser. In the context of R-Tronic to Gated wiring, it is recommended to use a plug-n-play approach when connecting a motor from an R-Tronic vehicle to a gated vehicle. Regarding the remaining wiring components, I am uncertain.
If the factory + tune is unnecessary, are I allowed to use my existing ECU and immobiliser to install the engine?
I am now engaged in the process of obtaining visas.
Given that my vehicle is equipped with a dual turbo and a personalised tune, it would be preferable if I could avoid the need to reprogramme another ECU.
I am also seeking a reputable establishment in close proximity to Reno, NV. I would much appreciate any ideas. Thank you.
