Glazed with ceramic
QuirkyPixel
Indeed, I own a 16-year-old automobile, and I encourage you to personally see its condition.
Engaged in artistic and creative pursuits, reminiscent of the City & Guilds artistic tradition.
The components encompassing the outside of an automobile, including the bodywork, wheels, and glass (except the windscreen), are of particular interest for analysis and examination. I have a strong affinity for the subject matter.
I am determined to ensure that no other individuals have access to my vehicles.
The aforementioned materials were provided to me for the purpose of conducting an experimental trial. Although it may not be the most costly option, the effectiveness of a product is contingent upon factors like as its application method and the number of coats applied.
The eBay listing titled "9H MR FIX ORIGINAL- SUPER CERAMIC CAR COATING TV PRODUCTS" offers a ceramic car coating product known as 9H MR FIX ORIGINAL. This coating is advertised as having superior properties and is intended for use on automobiles.
The application process is straightforward. The preparatory work is the crucial element. The surface must be thoroughly cleaned and devoid of any residual wax or other substances. After using a clay bar to remove contaminants, I proceeded to perform a meticulous application of a microfiber orbital polisher. Finally, I concluded the process by employing a panel wipe solution prior to the application of the desired substance. Building muscle mass, which is sometimes referred to as "buffing up," is an enjoyable aspect of physical fitness. It has a remarkable ability to resist both dirt and water.
Products without a specific brand originating from online retailers such as "Newfrog" or "Tomtop" may be procured directly from China within an approximate timeframe of two weeks.
The cost of a 125ml spray bottle, including shipment, is around £6.
Undoubtedly, this polish exhibits the highest level of water repellency I have seen so far. The application process is straightforward, resembling that of Mr. Sheen. It involves spraying the substance (preferably on a day with less wind) and then buffing it until a noticeable shine is achieved.
The task was completed three months ago, and with each subsequent washing, the appearance is restored as if the task had been freshly completed.
I have proficiently administered Gyeon Duraflex on several surfaces, and it has commendable qualities, although at a considerable cost. In consideration of the matter, it may be said that with proper pre-application preparation, a sealant of commendable quality, while not necessary of high cost, might provide comparable outcomes albeit with a potentially heightened need for care.
The efficacy of ceramic coating has been empirically shown, since it effectively safeguards and preserves the integrity of the vehicle. I would recommend using a meticulous cleaning technique in order to preserve the vehicle's condition, and utilising the company's spray sealants periodically throughout the washing process to aid in the preservation of the protective covering.
