Tire degradation
VVC-Geeza
Greetings
My Sporty HEV had its first service on Friday in November 2023. Everything is OK; but, I was slightly taken aback when the Vehicle Health Check indicated two faults need prompt care. The inquiry pertains to the two front tires (Continental Contact 6 235/55/R18V XL), which had a tread depth of 4mm. The dealership provided a quotation of £402 for the replacement of these tires, despite the vehicle being just one year old and having completed only 4,000 kilometres. The service representative said that they mark tires with 4mm or less, therefore I am optimistic about achieving much higher mileage from them in the next year.
I had Michelin Primacy run-flat tires on my last vehicle, a Mercedes E-Class estate, which I owned from new. After 4.5 years and 20,000 miles, the original tires were still fitted.
I recommend rotating the tires from front to back, since the rear tires often do not wear out as rapidly, which may help prolong their lifespan. I had Continental tires on my previous 2020 Sportage and had them rotated at each service appointment. Accumulated 17,500 miles on them; nonetheless, I was dissatisfied and changed them immediately after the vehicle's MOT.
All components contribute to eco tires, which purportedly possess an extended tread lifespan thanks to the used compounds. (reduced weight, rolling resistance, etc.)
The depth of the rears is not specified. If superior, I would rotate to equalise wear. The HEV exhibits considerable vigour from a stationary position, resulting in more wear on the front wheels compared to the rear.
Mine measure 4mm with a comparative of slightly under 8K.
