Maintaining the soft top in optimal condition?
migueldosantos77
I have acquired my first soft top, which operates manually for opening and closing.
I have seen several posters seeking assistance with their damaged soft tops, as well as many that are significantly faded.
Mine is in immaculate condition for its age; it will mostly be outside but sheltered beneath a cover.
What recommendations exist to maintain this in optimal condition?
Is maintaining it in a folded position (open) optimal, provided it is stored in a garage?
Or maintaining it in an extended (closed) position.
Should I refrain from exposure to rain?
a conventional canvas cover and instruction handbook.
I store it inside, but I maintain the lid at an elevated position. Maintains its tension to prevent any concerns of contraction and excessive tightness. It seems to be more beneficial for it.
Moreover, maintaining it ensures it remains dry and clean. If it remains perpetually closed, any accumulation of moisture may promote the proliferation of microorganisms.
Maintains the clarity of the plastic back window as well. Constantly folded, it will abrade against itself, resulting in a lacklustre appearance.
I also use Autoglym products on my vehicle. There is a bottle of foamy cleaning and a bottle of waterproofing, purchased as a package. Once every season. Exercise caution with the cleaning, since it may significantly mar the paintwork. I used an orbital polisher and Meguiar's polish to remove it. It dried on me, so it may be OK if you prevent it from drying. However, the guidelines explicitly state to "avoid stepping on painted surfaces."
I generally avoid parking convertible automobiles outside, since sunlight adversely affects the fabric stitching and rear window. However, if that is all you own, it is all you possess.
Thank you.
It was a "retirement gift" to myself 5-6 years before. I have always expressed a desire to possess at least one Corvette before I pass away.
Utilised a little portion of my severance. Acquired it for $9,000, with minor mechanical, electrical, and cosmetic issues that I was able to rectify easily.
It has little over 100,000 km and operates as if it were new.
It is July, a bright day for cruising with my partner.
However, it will also perform very well on a mountain road.
Thank you, everyone. I have a strong preference for Autoglym goods and am considering purchasing a kit.
I also feel that water poses a significant threat to these fabric shirts.
I own a vehicle cover that is almost waterproof but gets moist during rainfall. If water poses a significant issue, I will likely seek an additional plastic sheet to protect the roof prior to applying the car cover.
