2007 W211 E320 CDI, noise from 7G-speed gearbox
Needsnewtyres2
Greetings, everyone!
I am a newcomer seeking guidance.
I have been researching but have not seen any information similar to the issue/noise I am having with my vehicle, so I thought I would seek out to see if anybody can assist me in resolving this matter.
I have had my 2007 E320 sport sedan for about one year, and I think the gearbox code is 722.9. I have recently observed an unusual metallic sound emanating from the vicinity of the torque converter.
Here is the current situation:
    Upon initiating the engine in a cold state, the noise is hardly perceptible.
    The noise diminishes when I shift the vehicle into drive when the engine is cold.
    When the engine reaches operating temperature, the noise intensifies when in neutral or park.
    I have replaced the gearbox oil and filter according to manufacturer specifications, but it did not resolve the issue.
    The vehicle transitions smoothly when warm; however, I have observed that when cold and downshifting from second to first gear, the experience is rather jarring (but devoid of clunking).
The gearbox seems to function OK; nonetheless, the noise is causing me some concern. Has anybody had a similar situation or have any recommendations on the potential causes?
I have also included an audio clip of the vehicle in neutral, transitioning to drive, and then reverting to neutral, if that is of assistance.
Thank you in advance for any assistance!
My 2011 E350CDI with a 7G gearbox has a little roughness while shifting from 2nd to 1st gear when cold. Replacing the engine mounts and gearbox mount has, if anything, intensified that specific characteristic. However, all other shifting characteristics have been smoother and quieter after the mounts were altered.
Similarly, my 2013 W204 had a clunky upshift when cold, which is a known trait. The ATF has been modified and the TCU software has been upgraded, among other changes.
Consequently, 2013 vehicles will include the subsequent G7+ variation, leaving uncertainty over the impact on the OP's earlier 7G model.
The original post states that replacing the ATF fluid and filter has not ameliorated the condition.
The date of the change was not specified; however, given that it was executed in an attempt to resolve the problem, I infer that it occurred at the recent conclusion of the gearbox oil and filter service period.
Nonetheless, Op, might it be that the fill level is inaccurate? This is not a critique; I am only attempting to identify the straightforward and cost-effective solutions first.
