colinallcars Posted March 5, 2024 Share Posted March 5, 2024 Hello, everyone. I own a 1997 R129 SL500 and it is experiencing a problem. The occurrence started last week. While travelling at a speed of around 5 mph in traffic, the vehicle had a sudden and brief decrease followed by a rapid increase in engine revolutions. Subsequently, all dashboard lights illuminated and the engine stopped. I had no difficulty restarting the vehicle and thereafter drove one mile back home. A few days later, I drove a short distance without any issues, then it stuck at traffic lights shortly after. No fuel problems, no spluttering or misfiring, simply sudden illumination of dashboard lights and engine shutdown. I brought it to my independent Mercedes specialist who connected it to Star diagnostic system and found no issues. He said that it may be a crank position sensor, so he purchased one. I drove to his garage without any problems, but it stuck again when I stopped at adjacent traffic signals. He installed the sensor and hoped for the best, but unfortunately, the engine began briefly and then stopped again. I drove a little distance home and the vehicle stalled once while stopped, but restarted without any issues and I was able to drive back. I waited for a few minutes with the engine running outside the home. Suddenly, there was a brief reduction in revolutions per minute, causing the engine to stall in the momentarily before restarting without any problems. I'm curious whether it occurs more often when the engine is heated. The car will get a check-up by a traditional Mercedes expert on Monday, which is annoying. I intended to drive 25 miles today, which may be OK, but I am concerned about the possibility of stalling at high speed on a dual road. Has anybody encountered this and can provide any recommendations? Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted March 5, 2024 Share Posted March 5, 2024 The CPS or cam sensors would have triggered a fault code, suggesting a possible issue with fuel, anti-surge system, or an unmonitored component. Hope you manage to fix it. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted March 5, 2024 Share Posted March 5, 2024 When was the gearbox last serviced or the fluid level checked? A torque converter problem may cause an automated automobile to stall at moderate speeds. It is unlikely that any codes will be shown. Quote Link to comment Share on other sites More sharing options...
norbury.brook Posted March 5, 2024 Share Posted March 5, 2024 I had a problem where the engine would start but then promptly shut off. Initially suspected the crank sensor, replaced it, but did not see any improvement. Battery replaced successfully. I believe that the decrease in voltage after the start-up led to the ECU experiencing a brown-out and resetting. It is possible that the battery is experiencing sporadic internal contact issues or is beginning to deteriorate. Quote Link to comment Share on other sites More sharing options...
allmightyASTON Posted March 5, 2024 Share Posted March 5, 2024 Has the fuel pressure at the injector rail been verified for consistency? Have you examined the fuel filter? The list continues... Quote Link to comment Share on other sites More sharing options...
Black_raven Posted March 5, 2024 Share Posted March 5, 2024 On my CLK500, this indicated the start of a Mass Air Flow (MAF) sensor malfunction. Should I check the diagnostic trouble codes to confirm? Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted March 5, 2024 Share Posted March 5, 2024 It seems like a gasoline-related issue. I suggest having them connect a pressure gauge to the fuel line to monitor the pressure while the engine runs at various RPMs. Quote Link to comment Share on other sites More sharing options...
colinallcars Posted March 5, 2024 Author Share Posted March 5, 2024 The gearbox was serviced a few years ago and has not been inspected since. It changes smoothly without any problems. I will ensure that they verify. Thank you. Quote Link to comment Share on other sites More sharing options...
colinallcars Posted March 5, 2024 Author Share Posted March 5, 2024 No codes are shown on the Star system. A malfunctioning Mass Air Flow (MAF) sensor may lead to irregular idling and driving, however in this case, it only sometimes turns off while stopping in traffic or at lights. Quote Link to comment Share on other sites More sharing options...
colinallcars Posted March 5, 2024 Author Share Posted March 5, 2024 It functions flawlessly but shuts off while stopped at traffic lights or stationary. No sputtering, misfiring, or jerking, simply as if I had turned off the ignition. Quote Link to comment Share on other sites More sharing options...
johnnyb44 Posted March 5, 2024 Share Posted March 5, 2024 I would inspect for intake air leaks. Quote Link to comment Share on other sites More sharing options...
