Clattering in the anterior suspension
I experienced a clunk in the right front when I used the brakes forcefully or over a speed bump at an elevated speed.
I altered my upper arms, but it proved ineffective. The top ball joint had ruptured, resulting in grease leakage, which led me to that conclusion.
I replaced the lower arms, which completely resolved the issue; the problem was a lower arm bushing.
The repair was rather economical using aftermarket arms; nevertheless, detaching the ball joint conical bolt from the steering knuckle proved to be a challenging task.
Based on all available information, replacing alone the bushings is rather difficult without the appropriate press and inserts. You would also need to purchase the ball joint.
Purchasing an aftermarket arm is much simpler, since they are priced at little over $100.
Changing the arms is not a difficult task at all.
Once I successfully freed the ball joint from the knuckle, I need less than two hours to remove the arm and install the new one.
I recently seen videos demonstrating the procedure.
Additionally, it is far more manageable with the appropriate equipment; I acquired a dead blow hammer, a map gas torch, and ratcheting wrenches.
Alignment is necessary after the alteration of the lower arms. However, it is not instantaneous; I used my vehicle for many days until the task was completed.
The vehicle proceeded forward but would only veer and maintain its position if I slightly adjusted the steering wheel to the left or right. I used paint markings to achieve optimal alignment similar to its previous state.
It resembles a new vehicle once again; the effort was undoubtedly worthwhile.
