GLC 250d produces a ticking sound when the wheel is turned.
MDMH757
I recently acquired a 2017 Mercedes GLC 250d x253 with 50,000 miles from the original owner. The vehicle produces a ticking noise, which I have documented, when the steering wheel is turned to the left. I am uncertain whether this occurs when we turn right. I inadvertently captured it on camera. The vehicle occasionally exhibits a sensation of traversing an obstruction in the road while reversing with full or partial steering lock, and forum discussions suggest this phenomenon may be referred to as "crabbing."? I enquired with the original owner, who stated that warranty repair was performed to address the "crabbing" issue; yet, the problem appears to persist. Is there any information on a ticking noise when rotating the steering wheel, as well as a clunking sensation when reversing and turning? I have encountered discussions indicating that the problem may pertain to the steering knuckle, and that Mercedes might provide coverage due to it being a manufacturing defect. I possess a Mercedes extended warranty. Thank you for your attention.
Winter tires or all-season tires are necessary to prevent crabbing. I installed XL tires on my GLC; a significant error. I refrain from fully locking the vehicle on cooler mornings. I will either install crossclimate tires or adapt to the current situation.
Unable to assist with the ticking.
I possess a 2021 GLC equipped with Michelin Pilot Sport SUV tires (non-runflat) and have not seen this issue whatsoever.
I suspect there was a modification for the suspension of certain earlier vehicles, but I cannot confirm this with certainty.
I admire these vehicles; best of luck with yours.
I possessed an Audi that exhibited similar behaviour.
The brake pads (Mintex) were found to be ill-fitting, exhibiting significant looseness and movement within the calliper.
It ceased when I applied the brakes, when I removed my foot.
Generic pads from ECP resolved the issue.
