MDMH757 Posted January 9 Share Posted January 9 Greetings, I attempted to install a set of winter wheels on my 2019 W213 today and discovered that the original equipment wheel bolts are excessively lengthy. The wheels are OZ-MSW 5 x 112 19x7.5, equipped with 245/45 R19 winter tires. I can either obtain spacers or acquire shorter wheel bolts. I believe I may possess a compatible component utilised on a 2002 Audi S3, M14 x 1.5, with a thread length of 30mm; however, I am uncertain whether it is ball or tapered. I suspect the wheels utilise a 60-degree taper, given they originated from an F30 BMW. Is there a straightforward method to verify this? I possess a steel space saver that likely requires shorter bolts, originally intended for a 2015 Audi A4. Could someone verify if my OE wheels are ball or tapered? 2. Is there a swift and straightforward method to ascertain whether I require ball or tapered bolts for my MSW alloys? 3. Is there a swift and straightforward method to ascertain whether I require ball or tapered bolts for my Audi A4 space saver? Thank you Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted January 9 Author Share Posted January 9 Is there a lack of knowledge among all? Quote Link to comment Share on other sites More sharing options...
peakroach Posted January 9 Share Posted January 9 The lug bolts for your Audi are of the radius seat kind. Quote Link to comment Share on other sites More sharing options...
HOV Posted January 9 Share Posted January 9 If you possess a steel space saving spare tire, the shorter bolts required for its installation are typically included with the vehicle and are generally located within the polystyrene holder that accommodates the jack, wheel wedge and warning triangle. Quote Link to comment Share on other sites More sharing options...
DMGRS Posted January 9 Share Posted January 9 Aftermarket wheels typically require different bolts; I experienced this with a W211 while transitioning from aftermarket to OEM, resulting in the bolts being too short. Essentially, the opposite of your actions. Visit a wheel or tire establishment; they should possess bolts available for purchase. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted January 9 Author Share Posted January 9 My 2019 E400D is not equipped with any form of spare tyre or sealant. It is fitted with run-flat tires as standard. The vehicle is equipped with Eagle F1 MO tires, however they are not run-flat (RF) variants. The 19" space saver was obtained from a 2015 Audi A5. No original equipment wheel bolts; the current ones are excessively lengthy. The 19" winter wheels and tires from MSW/OZ are designed for a BMW 530 G30. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted January 9 Author Share Posted January 9 Indeed, I am cognisant of that; I am merely attempting to ascertain the precise requirements. Visiting a wheel shop is a commendable suggestion; however, I am uncertain of the availability of such establishments in this area, as most have transitioned to online platforms. Quote Link to comment Share on other sites More sharing options...
MDMH757 Posted January 9 Author Share Posted January 9 Indeed, I am cognisant of that; I am merely attempting to ascertain the precise requirements. Visiting a wheel shop is a commendable suggestion; however, I am uncertain about the availability of such establishments in our region, as most have transitioned to online platforms. Quote Link to comment Share on other sites More sharing options...
torque2me Posted January 9 Share Posted January 9 What is your location in London? I am aware of several contacts you can reach out to, depending on your location. Quote Link to comment Share on other sites More sharing options...
