Check the pressure of the tires on your A238 E Class Cabriolet.
mrnobady
My fuel filler cap tyre pressure label is gone after I just upgraded to an E Class Cabriolet A238 E220d 19 Plate. Is there a way I can verify if the photo that someone generously posted to a Facebook group matches the one that the dealership has provided? I own 275/35R19 in the front and 245/40R19 in the rear.
When transporting four people or more, the distinction solely applies to the back tires. I would recommend starting at 39 and seeing how you do; if you feel the need to modify upwards, you can always go to the other chart that contains 42.
I usually leave the psi constant on my W213 20s, even though the suggested pressure is 35, since I seldom have a full load and don't want to bother changing it and because I haven't seen any negative effects. However, I did read that you should increase it by 2 psi.
Choosing a pressure level in the middle of the suggested and maximum range is typically what we suggest. Never fill a tyre to more than the maximum pressure warning written on the side.
Start with a little more pressure than advised, and if the ride quality is compromised, you can lower the pressure. It's better to err on the side of caution.
Get in touch with an EPC specialist if you suffer from obsessive-compulsive disorder; they will be able to inform you which sticker is right for your vehicle identification number (VIN). Additionally, I recommend ordering the sticker from MB once you get the right P/N.
